Modifying a Delco radio for IPod input?
Let me try this on this forum......not getting much response other places?
OK, so I have a very nice AM/FM stereo stock radio in my '75 SS el Camino, plays nice, have 4 speakers, 2 Delco (10 ohm) stock ones in the front under the dash, and 2 in the doors (aftermarket 6"x9" 8 ohm)......
I have an aftermarket AM/FM stereo radio in my '72 SS 454 el Camino, looks like the original, again 4 speakers but it also has an 1/8" jack where I can plug in my IPod and play my own music.....
Is there a way to "EASILY" modify the stock Delco radio in my '75 so I can play my IPod music there as well? I am thinking there must be a way to add a jack to plug in the IPod before the amp in the radio, just like the one I have in my '72?
I don't want to send it out to anyone........and if its going to cost tooooooo much, might be just easier to buy another one of the aftermarket ones that look like the original and go that route......
Anyone have input or comments?
BTW, I have an extra Delco AM/FM mono radio I can use as a guinea pig........
Bruce
Bruce
BAS-Sr- G3GM Member
Re: Modifying a Delco radio for IPod input?
Your best bet would be to add an FM transmitter so you can play your Ipod through your stereo. The better ones seem to be the ones that connect directly to your antenna.
http://www.amazon.com/FM-Transmitters-MP3-Player-Accessories/b?ie=UTF8&node=13981621
Someone using RediRad
https://www.youtube.com/watch?v=de5RbKvdnjQ
https://rediscoveradio.com/index.php?main_page=index&cPath=1&zenid=0dfd4b1908a8246817c4d49dc90104c6
Hawk03- G3GM Enthusiast
Thanks Hawk, but not the way I want to go.
Only want to add to the existing radio or do an aftermarket one that has the jack built in.
BAS-Sr- G3GM Member
Well what I would do. 6$ on amazon and I am sure you could get this locally as well. Probaby Radio Shack or something. Mount the 1/8 female port in the dash near the radio and connect the rca female ports to a long enough rca cable to reach your amp. then it should play through the amp if you have one that is.
http://www.amazon.com/YCS-Basics-3-5mm-female-cable/dp/B00D64J64S/ref=sr_1_1?ie=UTF8&qid=1412014920&sr=8-1&keywords=rca+female+to+1%2F8+female
If you wanted to keep it looking stock you could mount the port in your ash tray for a cool hidden feature.
driveit wrote:Well what I would do. 6$ on amazon and I am sure you could get this locally as well. Probaby Radio Shack or something. Mount the 1/8 female port in the dash near the radio and connect the rca female ports to a long enough rca cable to reach your amp. then it should play through the amp if you have one that is.
No, don't have an amp. Trying to hook a line into the radio amp before the speakers.
Need a wiring diagram or if someone else has done this, how did they do it?
BAS-Sr- G3GM Member
I don't know the stock wiring but this article is a good start on what you might want to do. It seems pretty straight forward once you know the wire colors.
http://autoxer.skiblack.com/nallm/mp3jackinamfm.htm
Procedure looks pretty straight forward, just wish it had the wiring info for the AM/FM that is in a '75! :-)
BAS-Sr- G3GM Member
If you have a oscilloscope or can borrow one I would start by hooking up the radio on a bench and probing the amplifier section with the scope and try to find the left and right audio signal, at preamp level of course, and with a little luck you might find the logical place to tap in with a switch to divert the input from an aux jack. noise can be an issue. You might need special wire that is insulated with a ground to avoid inducing a ton of ignition noise into the audio signal. I like your idea and I hope you figure it out. I was thinking of doing this but I am gonna go new and get BT and all the features since I am doing a resto mod.
ratnfested- G3GM Member
If you can figure out where to tap into the input of the pre-amp, a switching jack, or even a toggle switch could be used to block the tuner output and connect to the pre-amp input.
Shielded wire will be necessary on wiring to the pre-amp input......
» How to use your Bluetooth Phone with your original Delco Radio to keep all original.
» Your input please....
» Front Delco Morain calipers rebuild kit
Wed Oct 23, 2024 10:05 am by Redscampi
» Things are looking up
Wed Oct 23, 2024 7:56 am by Redscampi
» Central Texas Noob
Wed Oct 23, 2024 7:33 am by Redscampi
Tue Oct 22, 2024 11:18 pm by Limey SE
» vinyl top removal
Tue Oct 22, 2024 8:28 pm by 76Chevelle2Tone
Mon Oct 21, 2024 12:58 pm by 76Chevelle2Tone
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
