73 laguna trim
G3GM :: Classifieds :: Wanted
73 laguna trim
I went to remove the trim that goes under the rear window over the vinyl top and it broke . I need all 3 pieces hope someone can help
lagunaman- G3GM Member
Re: 73 laguna trim
Do you mean the metal trim or something else?
76Chevelle2Tone- G3GM Member
Re: 73 laguna trim
This is the trim it's chrome and covers the bottom of the vinyl top runs under the quarter windows and below the rear window trim . Goes from door openings to door openings and is above the trunk its metal and about a 1/4 in diameter and square held on with clips
Re: 73 laguna trim
That should be something that could be found in a JY. This Ebay seller unfortunately only has the upper chrome for the rear window but you could let him know what you are looking for. I assume the Laguna molding is the same as the Malibu?
https://www.ebay.com/sch/i.html?_ssn=406&store_name=406vintagefarms&_oac=1
Re: 73 laguna trim
I checked and nothing here in the wrecking yards. Nearest one is Fresno CA and may call them ? I was hoping some one on here may have one since most owners do away with vinyl tops
Re: 73 laguna trim
It's always a timing issue on these body parts that aren't reproed. Six months from now or six months ago there could be several available. Fortunately it's just cosmetic. If I see something I'll let you know. I would touch bases with the ebay seller I linked to,. He is the most consistent seller in terms of parting G3 cars I've run across.
Re: 73 laguna trim
I wrote him and said he didn't have any so back to the group
Re: 73 laguna trim
I'm trying to understand what you mean by "breaking" the trim. Â Are you talking about the interlocking tabs on the corner pcs breaking away from the center piece? Â I've got a few trim pcs that I might be able to help with, but not sure if they are from a '73 or '74-'77. Â Or, if they are all the same? Â Let's start by getting me a part number that is embossed on the backside of the corner pcs and I can check with what I have.
- Street Cred : 78
Re: 73 laguna trim
Mcarlo
Looking at pictures of the rear window of 73 Lagunas it looks like the same metal trim I have on my 76 Malibu. I assumed he broke the tabs as it would hard to break the metal trim, although it could get bent I suppose.
Re: 73 laguna trim
It'snot the tabs or the posts . The piece is 5 pieces there are 3 are straight with a slight curve and 2 pieces that connect 3 of them . I wish I had a picture
Re: 73 laguna trim
Thank you that's what I am looking for the belt line !!! I just down loaded that same pic to show everyone . You saved the day !!!!
Re: 73 laguna trim
OK so where is the damage given the photo?
Re: 73 laguna trim
I figured it was the belt line moldings, but am still confused as to what is broken if the tabs and mtg studs for what I call the corner bend pcs are intact. Those are usually the ones that turn brittle from age and break during removal because they are pot metal. So, to summarize you have the (2) side trims that extend from the door openings along the upper qtr panels that connect to (2) corner bend trim pieces that then connect to the (1) long trim that runs along the back between the rear window and trunk lid (5 pcs total).
- Street Cred : 78
» Wanted: Laguna bumper trim
» wanted : pair 73-74 Laguna headlight trim
» are the small opra window trim quarter moldings the same on a 74 cutlass and a 74 laguna
Today at 9:51 am by g3chevy / Mr Pontiac
» Chevelle Power Trunk Release
Today at 9:31 am by g3chevy / Mr Pontiac
» 73 laguna trim
Today at 12:44 am by Mcarlo77
» fuel gauge malfunction?
Thu Oct 03, 2024 5:44 pm by 76Chevelle2Tone
» G3 Chevy rims- help ID these
Mon Sep 30, 2024 12:49 am by Limey SE
» Buckskin vinyl washout
Thu Sep 26, 2024 10:43 am by Mcarlo77
» You know I love a good bike
Thu Sep 26, 2024 6:22 am by Finn Monte
» MONTE FRONT BUMPER TUCK
Tue Sep 24, 2024 11:55 am by Finn Monte
» Life & Back On The Radio
Sat Sep 21, 2024 10:15 am by Limey SE
» Tips for Dash Removal?
Fri Sep 20, 2024 5:42 pm by 73 ss wgn
