1977 rear gear swap
+8
w451973
Brainstain
12 posters
Page 2 of 5
Page 2 of 5 • 1, 2, 3, 4, 5
Re: 1977 rear gear swap
I think its the posi unit you are thinking about. There is a spacer available to fix that problem.Brainstain wrote:At one time I was told that the 2.56 housings were smaller than the 2.76 and up housings and that fears wouldn't fit in them. I'm not sure if there is any truth to this or not?
I think the housing you found will suit you fine. Go take a look at it, the rear does look like it was out of a car that probably saw some winter road salt. But as long as the mounting ears are not pitted on the inside diameter and a new bushing will seat and it looks functional then go for it. See if they will let pull the cover and confirm what is in there.
Thanks everyone - I'll just role under my car tonight and see what's what, and then get in touch with the seller. I'm sure pulling the cover won't be a big deal.
What am I looking for? I know what a posi looks like, and I know what new stuff looks like but I'd have no idea if it was all wrong . . .
And YES this probably saw winter snow and salt.
enjoy
enjoy
Dinomyte- Donating Member
I've been under the car just now and I was wrong. Don't ask, I don't know what I was remembering.
The pot looks exactly the same. So it will just bolt right in? What else will I need that I can't transfer from the old one, and what do I need to look for when I go see this thing?
Thanks and again sorry for the confusion.
enjoy
enjoy
My '77 Elco had the 2.56 rear gears. I had it down a couple of times for rear seals and axle bearings. It was an 8.5.
There is an ident code on the right axle tube, on the front side, a bit away from the gear housing. Letters & numbers to tell what it is.
Casting number on axle tube....the best I can make out is 4zt076g. Casting on yoke is 1251502.
anybody know what it all means or where to look for details?
thanks
thanks
Your looking for tbe stamped number not the casting number. If your at your passenger side wheel looking at it face on. Three o'clock position of tbe wheel which would.be.towards the front of tbe car. Follow tbree oclock along the axle tube until you get to abour 3-5 inches from the diff. Hit that area with a wire brush. Thats where number should be.
I see what you're saying, I think one of those is the stamped number, the one starting with 4.
That was a copy and paste from the sellers email. I think I'm going to have to bite the bullet and go look for myself. I know the thing has been rebuilt so looking inside is a must, I just wanted to make sure it would fit and that all was good with the size and layout at least before driving 2 hours.
Has anybody got measurements for the rear end in our cars?
Distance between backing plates.
Distance between lower control arm mounts. and there size?
Distance between spring mounts.
I'm going out Sunday to take a look at this thing and wanted to be sure it will fit. Guy says it will but he's already made one mistake. . .
Got the rear end home last night.
Now I need to find control arms (Mine are for a non sway bar car and I've got a sway bar I want to install) The local Car Quest which has always been great can't get anything other than a Hotchkis kit that is about $600, which is a little much just to get a sway bar in.
What have you guys used and from where? I'm not into racing, but do want a car that handles better than she did stock.
Any help would be greatly appreciated.
thanks, Dino
thanks, Dino
Pmtfabrication.com Mine came from eBay, but you can buy them direct.
Just order up the.sway bar inserts and bolt tbem into.your arms. I believe the inserts from the late model.caprice fit as well.
If you choose this route, i have two from a '95 impala you can have.Joe73 wrote:Just order up the.sway bar inserts and bolt tbem into.your arms. I believe the inserts from the late model.caprice fit as well.
Last edited by dynchel on Fri Jun 20, 2014 1:57 pm; edited 1 time in total (Reason for editing : added picture)
dynchel wrote:If you choose this route, i have two from a '95 impala you can have.Joe73 wrote:Just order up the.sway bar inserts and bolt tbem into.your arms. I believe the inserts from the late model.caprice fit as well.
Thanks mate. That means the sway bar from the '95 Impala I have is sure to fit.
I'm going to see if I can find a pair local to me as customs is sometimes an issue, and without an official receipt it becomes a royal pain.
My current lower control arms don't have bolt holes or anything for the inserts. Anyone got measurements for them?
This is a great help.
Thanks so much. . .
The bar in my '74 is from a '95 SS so yes it will fit. Sorry no measurments, my oe arms weren't sway bar equipped either.
Here's what it looks like installed
Last edited by dynchel on Fri Jun 20, 2014 2:42 pm; edited 1 time in total (Reason for editing : added picture)
OK, so where do the holes to bolt the insert in need to be so that I don't get this sway bar too close or too far from the OE location?
Does this even matter so long as it doesn't interfere with anything?
Idk for sure, but I would think as long as it clears everything the exact location isn't that important.
The bar and inserts need to be as far back in the arm as possible. You won't have any clearance issues, there's quite a bit if room. The inserts will be the dimensions.
The farther back area lets the bar control the rear end better, since it's far from the front mounts of the arms, to where the leverage is.
So I guess the easiest way to do this is position the inserts in the LCAs while attached to the sway bar, mark everything out, then take them out and drill holes.
Dynchel - I may be taking you up on your offer, I've got a couple more yards to check with up north of here, and the dealer network, but so far nobody has inserts.
Dynchel - I've sent you an email.
Thanks so much for the inserts, I don't think there is a single pair in Canada.
This is what community is all about.
What type and how much friction modifier is anybody using in there diff?
Specifically those with an Auburn Posi unit. I've found multiple different answers to this, ranging from 1 to 2 "bottles" with no mention of how big the bottle is.
Thanks
Thanks
Ive installed a coue of auburns but i dont remember the amount. I'd give them a call. Better safe than sorry.
I sent them out this morning.
Dinomyte wrote:Dynchel - I've sent you an email.
» Frame Swap on 1977 Elcamino
» 8.8 rear swap in a wagon
» 77 to 73 Malibu Trunk/Taillight/Rear Bumper Swap
Page 2 of 5
Today at 7:06 pm by Limey SE
» Roll Call and Car showcase
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
» 1973 Grand Am
» Things are looking up
» Cool youtube video
