Need a pic,Unilite dizzy installed.SBC
Getting ready to start my motor.
The Vortec has no timing marks and no timing tab.
I'd like to get a basic idea how the unilite should be indexed.
The number 8 wire directly pointing toward the front,or the 1 and 8 staggered at a 45 degree angle.
Any pics appreciated.
Thanks.
Thanks.
Sinister- G3GM Member
Re: Need a pic,Unilite dizzy installed.SBC
It dosent matter where on the cap you put the number 1 plug wire as long as its followed by #8 and so forth. On my Unilite I have it set up like the stock GM location though.
x2, I'm running a vortec too, I just made whatever point the rotor was pointing at after the dizzy dropped all the way in #1. Just so happened that #1 ended at about the 5 o'clock position.
Biomedtech- G3GM Member
Just make sure the #1 cylinder is at coming up to TDC on Compression stroke. Makes it easier to reference. It will need a little advance to start, dont try to start it at 0 advance. It won't . Make SURE you have some break in lube in there or all your work will be for nothing and you will lose the cam.
» Roll Call and Car showcase
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
» 1973 Grand Am
» Things are looking up
» Cool youtube video
