what are the factory correct fasteners for center console, 4 speed insert, and glove box insert?
It is apparent to me that previous owners have had my center console in my 73 Chevelle SS 4 speed out and back in a bunch of times, as evidenced by the damage to the console base and the weird fasteners used. For example, the front 2 screws that hold my 4 speed insert on are these weird very small external hex head fasteners. That's not factory correct, right?? I believe all the thread insert clips are still present and correct, it's just that the screws have been incorrectly swapped out, lost, over the years.
Is there a guide to the correct factory fastener types for holding:
-the console base to the floor
-the 4 speed insert to the console base
-the center console "glove box" assembly to the console base and 4 speed insert
My factory manual doesn't show it. but I'd probably need a body/interior factory manual. Any help appreciated!
clanceman427- G3GM Enthusiast
Re: what are the factory correct fasteners for center console, 4 speed insert, and glove box insert?
So glad you asked this, I need center console fasteners too. The ziplock bag I have labeled "Center Console" doesn't include the screws. Not sure where I put them when I removed them.
Hawk03- G3GM Enthusiast
OK, got some good info here. I'm assuming the #8 fasteners called out are the chrome phillips head screws with the built-in washers, like what was used on the A pillar, B pillar, and C pillar trim and was also used on the ends of the upper door panels, and the rear 1/4 interior panels. Either that, or the black versions. But here is a great resource for what I asked for. Facebook in many ways is still the devil to me, but it's been a huge help in my 73 SS restoration
Kev, I've never seen chrome screws used on a center console. Go with the black.
Thanks Joe, makes sense. The #8 screws, are they Phillips heads, I'm guessing? And do they have the integrated washer, or just a black screw?
The ones for the glove box do have an integrated washer. The visible ones at the front of the console, in the gray area are Phillips with no washer as well as the ones right in front of the glove box. So basically, if the screws are visible, no washers. I don't recall exactly, but the ones in the glove box had hex heads. My 4 speed console is packed away and buried or I'd check for you.
I am in need of the #1 screw to fasten the console to the brackets. Googling 8.977 I receive the below results. Are these what I need? I don't need factory correct screws just something that will work with the brackets.
http://www.4speedconversions.com/9419402_r1.html
http://www.4speedconversions.com/9423284_r1.html
Great thanks Joe. I believe I have the correct hex head bolts that assemble the console base to the floor inside/below the glove box. I believe they are 1/4" bolts. Hawk03, your links show the coarse and fine thread 5/16" bolts which are too big I believe but I'll check on my car at lunch and report back.
Hawk03, the bolts are 1/4" diameter thread, 3/4" threaded length, with a one-piece hex head with collar, 3/8" hex. The thread is NOT a regular 1/4-20 UNC machine thread, it is coarser (less threads per inch). I think you need to source factory bolts or be OK with forcing a regular 1/4-20 UNC bolt into the bracket.
I will attach a photo of the bolt
I believe I have seen those bolts used on license plate holders on square body S-10s. My brain is not giving up the info on where else they might be used, but I have a few in my S10 collection. So I'm thinking GM dealers might have some hanging around.
crice63- Donating Member
clanceman427 wrote:Hawk03, the bolts are 1/4" diameter thread, 3/4" threaded length, with a one-piece hex head with collar, 3/8" hex. Â The thread is NOT a regular 1/4-20 UNC machine thread, it is coarser (less threads per inch). Â I think you need to source factory bolts or be OK with forcing a regular 1/4-20 UNC bolt into the bracket.
Thanks clanceman! That really helps. I will see if I can find anything on the web. I couldn't find anything in my miscellaneous stash that would work.
» Removing center console
» after market shifters within the stock floor console, and seat belt guide fasteners
» Center Console from previous gen
Today at 7:06 pm by Limey SE
» Roll Call and Car showcase
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
» 1973 Grand Am
» Things are looking up
» Cool youtube video
