Clutch adjustment help
The four speed swap is done be it's really fun to drive but the engagement from the pedal seems to be way to high in the pedal travel. Is there any way to adjust this for it to engage sooner in the pedal travel? Thanks guys-Justin
JF74chevelle- G3GM Member
Re: Clutch adjustment help
As long as you have the required "free play" at the pedal, thats the best you will do. If I remember correctly free play should be around 1 1/4". Free play is REAL important. If you dont have enough, the throwout bearing with be touching the plate fingers and wearing itself out quickly.
Diaphragm clutches grab up high. Three fingers grab closer to the floor. Diaphragm is the way to go with easy pedal pressure.
Like Joe said free play is most important. I would only modify the free play if you couldn't get enough travel for disengagement at the bottom. You only really want to have to push the pedal enough to shift it. Any excess travel just flexes the fingers more than needed.
On mine I have two holes on the z bar and depending g on which one you use it will change the geometry to move the pedal feel. Really just a matter of playing with it
McCauley5983- G3GM Enthusiast
The 2 holes on the z bar are used for the adjustment. You put the rod in one hole, tighten the adjustment so there is no slack, then put the rod in the other hole. That will give you the proper free play according to the gm manual. Although I'm not a fan of doing it that way.
Thats the reason for the 2 holes.
» Roll Call and Car showcase
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
» 1973 Grand Am
» Things are looking up
» Cool youtube video
