Is it possible? Front suspension rebuild..
+4
wbaker01
Hillbilly
8 posters
While the car is torn down, I need to rebuild the front suspension..One question I have is that I have heard it is better to not rebuild the front suspension with the engine/trans out of the car since the weight helps with reassembly BUT since I am painting/cleaning/etc. (and the engine/trans are out of the car) it sure would be nice to have the control arms off, etc. for a better cleaning/painting result..
I have seen videos that contradict needing having the engine/trans in for weight purposes and then others saying that the weight is absolutely needed..
Anyone care to share the real scoop on this and what you have experienced?
wbaker01- G3GM Member
Re: Is it possible? Front suspension rebuild..
I own an internal spring compressor so its never an issue. I wouldn't rely on backyard methods when you're dealing with a potentially deadly projectile. Auto parts stores these days loan tools like this out for free. My advice do it the right way with an internal spring compressor.
clanceman427- G3GM Enthusiast
Absolutely !! I rebuilt my whole chassis with nothing on it. I dont see any issue rebuilding the front end with no engine and trans. But just remember, only get the control arm attachment bolts close and not snugged down. Then when everything is assembled, bumpers, nose, whatever, bounce the front end a few times so it finds a position it likes. Then climb under and torque the control arm attachment bolts to spec. No issues at all.
I think Ant7377 will chime in about torquing the bolts with no weight on them.
And yes an internal spring compressor will work great. But I had my frame on a lift. I bolted on the upper and lower control arms. I let the lower arm hang vertically. I took the bolt out of my internal compressor, added a big washer to it and dropped it from top down through the shock hole. Put the spring up into the frame and used only the lower threaded part of the spring compressor on the threads of the bolt. I sucked the spring up into the frame pocket, swung the arm into place, spring needed to be tapped like a half inch towards the engine (but no engine in car) and tighten up the lower ball joint. Worked like a charm with only a slight scuff on the lower arm. Little touch up and done.
Also, if you haven't purchased loer control arm bushings yet there are 2 different sizes used in 73. Check your diameter to get the right ones.
The only thing to consider is with a rubber bushings don't pivot and the center actually is held and the bushing twists between the inner and outer surfaces. After all the weight is back in the car and it is on the ground I would loosen and retorque all the nuts/bolts so the center is at 0 twist at ride height. If you are using poly or other style bushings, I wouldn't worry.
Hillbilly- G3GM Member
Thanks for the advice..the front suspension on the car is original to the best of my knowledge (ball joints have rivets, control arm bushing are chunking away, etc.) It really needs a good rebuild! I'm not a real expert in this area and I have spring compressors, etc. but it would seem as though with the front suspension off, the frame cleaning/detailing would be much easier..
The poly bushings on my Elco are squeaking like crazy. I would not use them again. The supplied grease for them didn't keep them from groaning !
superlube with Teflon is what I use and no sqweeks. Get the small toothpaste like tube on eBay.
Also dont buy the cheapest bushings on the market rubber or othervise. I bought rubber bushings from opgi and rebuild my suspension all over. Ive had a hell of a time making them stop sqeaking. I had to replace most of the bushings to make it stop. Most of the rubber was already bad again, all dried out and also to ones in the front top a arms where was to small, so the shaft was not making contact with the bushing sleaves. So the bushings was twisting on the shaft making it squeak like crazy. I bought new moog bushings and you could easy see the difference in quality.
Just a heads up, since it is no fun taking the front suspension apart again to change stuff already changed once. It is not that much more money to buy the good quality over the bad. That goes for most of the parts ive used, the cheapest is usually crap, and usually dosent last long, If it fits at all. The worst are the cheap china made crome brackets, termostat housings and pullys. They fit poorly and they get rust pits first time you take the car out. So im done buying cheap parts.
Hs1973- G3GM Enthusiast
I bought and installed all Moog rubber parts for all suspension - no sqeak at all
builtnotbought- G3GM Member
I use anti-seize mixed with that poly lube and don't have problems.... I love polyurethane bushings.
brownbomber77- G3GM Member
» Front Delco Morain calipers rebuild kit
» Blue Collar Buick front suspension
» NASCAR type front splitter for 73 Laguna front end
» Roll Call and Car showcase
» Life & Back On The Radio
» fuel gauge malfunction?
» 1973 Grand Am Parts Needed
» 73 laguna trim
» 1973 Grand Am
» Things are looking up
» Cool youtube video
