Front Spring Compressor
+4
brownbomber77
8 posters
Page 2 of 2
Page 2 of 2 • 1, 2
Re: Front Spring Compressor
After you loosen the nuts try to bounce the front end up and down to settle it. Wont be easy because of the.new springs. Then tighten it.up.
What he said, and yes you just have to loosen them, not remove them.Joe73 wrote:After you loosen the nuts try to bounce the front end up and down to settle it. Wont be easy because of the.new springs. Then tighten it.up.
Thanks guys. It really needs to drop a little!
I use some 1/4 inch by 2 inch steel plate with holes drilled on either side. I compress the spring outside the car, install my compressor tool with 6 inch long bolts and install. When the spring is in place, I connect the spindle and undo the nuts and everything falls to the floor...with no danger of compressed energy exploding everywhere...haha
brownbomber77- G3GM Member
Got the front end aligned and put the back tires on the front as they were a bit taller. The front ones are now a little wider than the back, but I think that it does level it out a bit. Still no drop to the springs though. I don't expect it to. At least not enough to get the look I want.
What would you do?
Buy the same spring but with a 2 inch drop?
Buy a regular duty spring rather than the HD?
Cut out a coil or two?
What would you do?
i would (have) cut springs when facing this same problem. my experience is one coil = about one inch drop.
It needs about two inches of drop. I am thinking maybe a coil and a half?I don't want to go too far. I would really rather get a new spring instead of cut these. Doubt that is in the cards through unless someone wants to buy them from me. Alot of the coating has came off of them. Worst powder coating I have seen.
Pop em out, cut off what you want with a cut off wheel, paint them and reinstall.
X2, they are not returnable after install. plus what if you get new springs and it still does not sit hiow you want it, if you cut them it will sit lower than it does now.Joe73 wrote:Pop em out, cut off what you want with a cut off wheel, paint them and reinstall.
Last edited by dynchel on Mon Oct 28, 2013 10:24 am; edited 1 time in total (Reason for editing : added details)
I just didn't want to ruin the ride. It drives so good now. I am extremely impressed. I wonder if there would be a lot of difference?
i have cut big block springs (replaced in '95) and my car rides very nice....not quite as nice as my crown victoria d/d but close.
If you cut them the spring rate shouldn't change, they'll just be shorter. Unless they are progressive?
Brainstain- Donating Member
Would it be better to use a torch or a cutoff wheel?
Cut off wheel. With a torch you run the risk of inducing too much heat into the spring and it will lose tension.
Thats kinda what I thought. I will probably wait until the spring before tackling the job. Can't wait to get that mean stance.
I'd do it now. That way it's done in the spring and you can do other stuff.
Definitely cut off wheel. Ive watched guys.torch.them while on the lift to.the right. Height. Too hit or miss for me. Cut off wheel is the way to go.
So, I was thinking about the stance of my car again and how I hate it now and have found myself wondering. Can the spring be cut with a cut off wheel while in the car. Jack the front end up take the wheel off and so on.
Any thoughts?
Any thoughts?
That won't work, even if you manage to cut it (highly unlikely) you will never get the cut piece out as the spring will be holding pressure on it.
You could always get those bolt on clamps (auto zone should have them). Not the best way but won't take long to install.
Dang it. Those were so hard to put in. Maybe just cause they were so strong and tall. We had to almost compress them completely.
If you wanna drive up to Ohio I'll do it for you. I have some nice clamps that hold the spring compressed so putting them back in (after cutting them) is a snap. Probably an hour job.
It took us a whole day!
I would love to, but I don't think the old girl is up to it. The motor is a little sick right now. Hoping to do a rebuild on one this winter.
Page 2 of 2 • 1, 2
» Which Front Coil Spring?
» Another front spring question
» NASCAR type front splitter for 73 Laguna front end
Page 2 of 2
Today at 12:46 pm by tgaetto
» Have had a few questions
Today at 12:04 pm by Limey SE
» Roll Call and Car showcase
Today at 9:34 am by 76 Malibu
» vinyl top removal
Yesterday at 11:30 pm by 76Chevelle2Tone
» Things are looking up
Wed Oct 23, 2024 7:56 am by Redscampi
» Central Texas Noob
Wed Oct 23, 2024 7:33 am by Redscampi
Tue Oct 22, 2024 11:18 pm by Limey SE
Mon Oct 21, 2024 12:58 pm by 76Chevelle2Tone
» Life & Back On The Radio
» fuel gauge malfunction?
