Rusty's progress Carpet Chevk now onto floor replacement
+16
76Chevelle2Tone
zucchi
bucket
Zaptiah
S3SS
20 posters
Page 11 of 12
Page 11 of 12 • 1, 2, 3 ... , 10, 11, 12
Re: Rusty's progress Carpet Chevk now onto floor replacement
If your going metallic paint color Id go 600 prior to epoxy sealer (2k epoxy thinned 5-50% with reducer makes sealer). Apply sealer wait 30 min. then apply color. No sanding the sealer. If your not going metallic, then sand to 400.
Joe73 wrote:If your going metallic paint color Id go 600 prior to epoxy sealer (2k epoxy thinned 5-50% with reducer makes sealer). Apply sealer wait 30 min. then apply color. No sanding the sealer. If your not going metallic, then sand to 400.
Just going single stage Black Joe I don't think there is any Metallic in it but to error on the side of caution it wont hurt to go to 600 since will be black can never hurt right ?
Not a problem with 600. The bit finer is because of the metallics, you want them to lay correctly on a nice surface. Sometimes 400 effects the flakes laying down. Id also add just a touch of "activator" to your mixed urethane with thinner. Makes it a bit harder paint. Just like activator in clear coat.
Joe73 wrote: Id also add just a touch of "activator" to your mixed urethane with thinner. Makes it a bit harder paint. Just like activator in clear coat.
Not following you on this part Joe ?
I assume your going with urethane paint. The label will state its mix ratio, paint versus reducer. Id mix that up correctly, then add just an ounce of activator to the paint. Something along these lines.
https://www.eastwood.com/ew-urethane-activator-8-oz.html?gad_source=1&wcid=18669317220&wickedsource=google&wv=4
Some paints dont require an activator (sometimes referred to as a hardener) but I add a touch anyway.
What is urethane activator?
Universal Urethane Activator is a high quality catalyst formulated for use in urethane enamels. It provides a high level of gloss, combined with a hard, durable finish.
By no means do you need it !!! Its just personal choice. I put some in my single stage, my basecoat and clearcoat (required).
The details mention mix with activator in the last line. Make sure you purchase the activator as well.
Joe73 wrote:The details mention mix with activator in the last line. Make sure you purchase the activator as well.
yea that was the Plan Joe I have to get it all at once when ready for paint
Well didn't wanna take a chance with rain looming in the Skies to start spraying epoxy sealer on hood.........so got the Door panels cleaned primed and painted and I will be dipped I can not find the darn other 2 cans of Firethorne red I have so I still have one lower panel to paint yet when I find them cans LOL
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43465410](https://i.servimg.com/u/f19/12/68/92/73/43465410.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43306710](https://i.servimg.com/u/f19/12/68/92/73/43306710.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43464510](https://i.servimg.com/u/f19/12/68/92/73/43464510.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43292310](https://i.servimg.com/u/f19/12/68/92/73/43292310.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43465210](https://i.servimg.com/u/f19/12/68/92/73/43465210.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43466410](https://i.servimg.com/u/f19/12/68/92/73/43466410.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43281010](https://i.servimg.com/u/f19/12/68/92/73/43281010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43499110](https://i.servimg.com/u/f19/12/68/92/73/43499110.jpg)
- Street Cred : 35
Limey SE likes this post
It`s looking really good !
jpowen49- G3GM Member
in the next 36 hours saying another round of 3" of this crap also had 3" today some melted thank god
Well you can fool Mother Nature with a Garage!
76Chevelle2Tone- G3GM Member
76Chevelle2Tone wrote:Well you can fool Mother Nature with a Garage!
Yes sir agreed and new house will have one, just need to secure it first made offers on 4 different properties only to get out done by a thousand or so on offer and not being able to counter it
Well finally got some alone time with the SE today and hood plan is almost done 400 grit final sand then it can go into sealer and yes this is functional as well .... I am also gonna add an Aluminum mesh screen on the front of scoop for the hole didn't quite get covered by the main piece so have to "adjust" some metal there
P.S. The sheet metal screws are only temporary till I sand the 400 grit then will panel bond the scoop down for its final resting place they will come out when the panel bond is halfway cured like I did my floors in the other SE then long hair fiberglass bondo will fill in what needs to be and then If needed fill in any pin holes with skim coat of bondo the seal it up and start on the rest of Body work
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43752911](https://i.servimg.com/u/f19/12/68/92/73/43752911.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43720511](https://i.servimg.com/u/f19/12/68/92/73/43720511.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43737011](https://i.servimg.com/u/f19/12/68/92/73/43737011.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43489110](https://i.servimg.com/u/f19/12/68/92/73/43489110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43498410](https://i.servimg.com/u/f19/12/68/92/73/43498410.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43736910](https://i.servimg.com/u/f19/12/68/92/73/43736910.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43508010](https://i.servimg.com/u/f19/12/68/92/73/43508010.jpg)
Did a little Upgrading thanks to a friend Changing his Car he didnt like thepolished version for his car is just a street brawler / drag racer and dint like cleaning up after every event or race night So..... I inquired about the starter and told me if I took it all so he didnt have to mess with storing it in his shop UH Yea Ok sure that works ...... Was shocked
Anywho Ended up with a new to me (gently used )
Victor Jr Intake Manifold, Edelbrock high volume water pump (mine was a parts store junk) STARTER, FINALLY been trying for a few to find one worth a dung, Tall Valve covers and Flexplate to match up what I need this one is kinda wonky like a bad alignment of starter anyways Most of it is FIT UP for now to make sure it would work before adding Intake gaskets and siliconing the china walls and torquing down Been to windy to do hood so jumped right in on the motor to keeep it going Knees burn now so will rest them till Friday if No rain will get the starter and flex plate squared away.
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43529710](https://i.servimg.com/u/f19/12/68/92/73/43529710.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43719710](https://i.servimg.com/u/f19/12/68/92/73/43719710.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43721010](https://i.servimg.com/u/f19/12/68/92/73/43721010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43490110](https://i.servimg.com/u/f19/12/68/92/73/43490110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43498110](https://i.servimg.com/u/f19/12/68/92/73/43498110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43728410](https://i.servimg.com/u/f19/12/68/92/73/43728410.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43516010](https://i.servimg.com/u/f19/12/68/92/73/43516010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43529711](https://i.servimg.com/u/f19/12/68/92/73/43529711.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43767310](https://i.servimg.com/u/f19/12/68/92/73/43767310.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43732210](https://i.servimg.com/u/f19/12/68/92/73/43732210.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43758810](https://i.servimg.com/u/f19/12/68/92/73/43758810.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43765810](https://i.servimg.com/u/f19/12/68/92/73/43765810.jpg)
![Shocked](https://2img.net/i/fa/i/smiles/icon_eek.gif)
I forget, this is a 454 right? Make sure the flexplate is for an externally balanced engine, and that it is a 454 plate and not a 400 plate.
bracketchev1221 wrote:I forget, this is a 454 right? Make sure the flexplate is for an externally balanced engine, and that it is a 454 plate and not a 400 plate.
Yes 454 and yes it's a 454 plate but can't use he had alignment issue and got some teeth and the replacement will be same there inexpensive pretty much all this stuff came from a 496 BBC why I knew would fit
Car and motor in pic is what the parts came from
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 Receiv27](https://i.servimg.com/u/f19/12/68/92/73/receiv27.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 Receiv11](https://i.servimg.com/u/f19/12/68/92/73/receiv11.png)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 Receiv10](https://i.servimg.com/u/f19/12/68/92/73/receiv10.png)
Just a suggestion. You can use a small late model starter. Don't know if it's considered a mini starter but it is much smaller and about 15~20 pounds lighter than the stock one. Makes header fitment much easier and since it is smaller you won't get the dreaded heat soak with the big starter. Doesn't use the rear support since its so light.
You can find one on any late 90's small or big block V-8, Van, Truck, caprice, etc. You may be able to find a decent one at a pull a part or something. Be sure to grab the bolts too because they are specific to the small starter. I've been using one now for 10 years and hasn't given me any problems whatsoever.
73ss- G3GM Enthusiast
73ss wrote:Just a suggestion. You can use a small late model starter. Don't know if it's considered a mini starter but it is much smaller and about 15~20 pounds lighter than the stock one. .
This is that starter he only had the Support on it for his motor I am assuming but this is smaller than my stock one and he had huge headers on his Camaro Longtubes and fit fine Just FYI the camaro Headers are almost the same as I have his are just larger primary tubes than mine and he had no issues with it There the same headers that this starter was used on
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 Img_5310](https://i.servimg.com/u/f19/12/68/92/73/img_5310.jpg)
Looking good Limey! When do we get to hear it run? Gonna post a video on your channel?
- Street Cred : 35
g3chevy / Mr Pontiac wrote:Looking good Limey! When do we get to hear it run? Gonna post a video on your channel?
Thank you sir ty Everyone also...... Taking care of a smell I discovered and went to take it off to clean it and it literally just disintegrated in my hands and all fell out and OH MAN WHAT A RUSH That smell EEEEWWWW THAT SMELL this is the first one that I have had that was this bad and I dont wanna do it again So I think Just gonna sell the Heat Only box with fan and put a Plate over it I dont want no more critters what so ever in there EEEEEWWWWW
I have to put the new intake gaskets on, then get to Top dead center yes that close, then Put distributor in (its just resting in there for now I knew I had to pit intake gaskets on) finish putting in plugs, wires, Wire it up.... Then Test fit starter (should be an easy peasy deal there) if good wire the starter up, Then hook all my grounds up and give him a whirl and see if I blow it up or not LOL I wpould say barring any bad storms or health Issues with in the next 14 to 21 days I will fire it and yes It will be on the Youtubers
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43716310](https://i.servimg.com/u/f19/12/68/92/73/43716310.jpg)
THIS WAS THE SIZE OF TWO HEADS ( I should have put my ball cap next to it for the pics to show size BUT NOPE I didn't want the smell near my hat)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43726610](https://i.servimg.com/u/f19/12/68/92/73/43726610.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43736010](https://i.servimg.com/u/f19/12/68/92/73/43736010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 11 43729010](https://i.servimg.com/u/f19/12/68/92/73/43729010.jpg)
Was his motor an oval port head motor too? I thought you had the 781 heads on yours.
Page 11 of 12
» Ebay 4 door 73 parts
» Battery - Will Group 78 fit stock batter tray?
» Welcome abaord ElcaminoPasztor
» Four Door/Wagon Bucket Seats
» 2024 HOT ROD Power Tour Story on MSN
