Rusty's progress Carpet Chevk now onto floor replacement
+16
76Chevelle2Tone
zucchi
bucket
Zaptiah
S3SS
20 posters
Page 10 of 12
Page 10 of 12 • 1, 2, 3 ... 9, 10, 11, 12
Re: Rusty's progress Carpet Chevk now onto floor replacement
Yes the logo is bending the rods. I hope you can straighten them out properly. But if that black and red Chevelle was what was stored for 25 years I'm just stunned. How could anyone just store a car for decades that looked that nice?
76Chevelle2Tone- G3GM Member
There is still a lot of weight to add. My race car used to sit high with just the engine in it, but after I put all the extras on the motor the car came down a few inches.
My 1969 Grand Prix sat high like that in the front when I replaced the springs, ran it that way for a year to see if it would settle, it did not so I had one full coil cut and it then sat normal.
Iggy- G3GM Member
Doesn't someone make drop spindles for these cars?
Once you start messin' with springs, you change the suspension harmonics and can adversely affect handling; the A$$-end being way more squirrely when accelerating out of a turn for instance.
How about you fully assemble your car and test drive it before you commit to changing the front springs?
zucchi- G3GM Member
Re springs
Just out of curiosity since the subject has come up Detroit Springs is the only seller that I found that actually listed different springs for different models eg station wagon vs coupe. Everyone else seems to be issuing modded springs or what they call OEM springs without listing what they mean weight wise or component wise. Also GM altered the weight specs over the years. I believe my 76 gained 100 pounds from 77 to 81 in their manuals.
bracketchev1221 wrote:There is still a lot of weight to add. My race car used to sit high with just the engine in it, but after I put all the extras on the motor the car came down a few inches.
All I have to put on is drive side Header, transmission, exhaust, driveshaft and the battery will all that be enough weight to bring it down that much ??
I do have Impala 1" drop springs (front) for that in Case moment I will need them BUT will get all said items on the car first
Where is the balance point on these cars? At some point as you move backwards the rear springs are impacted more than the front obviously
I have new Moog Springs that were for a wagon installed and it lifted the back where I wanted it to be, Just need to do the front good and I will be happy AND it might be the dam driveway also at a slant for the Drive side doesn't look Bad
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 37627711](https://i.servimg.com/u/f19/12/68/92/73/37627711.jpg)
Yes but as you said you still have the driveshaft and transmission to install both of which should impact the rear springs too. I just have zero experience with tires of that size so I'm not sure where the frame should sit. But the front end looks very high to me at least.
Yea I have the springs in shed just dont want to pull the trigger on them till I make sure I still have to go to a Larger rear tire yet before putting on road so Might make a small difference as well these are just rollers not highway safe BUT good burnout tires after I break in Cam first, I want to go to a 325/50 15 or a 305/60 15 If i can find them if Not will be a 295/50 15
Transmission Crossmember O Limey 2
Ya buddy Gforce installed finally next is driveshaft if Mother nature will stop the rain for more than a few hours at a time, And as I was lowering the car down off the Bumper jack it begins raining yet again, And I tell ya now that is sitting at right Level the hood just barely I mean barley closes whewwww
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Old_cr10](https://i.servimg.com/u/f19/12/68/92/73/old_cr10.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 New_gf10](https://i.servimg.com/u/f19/12/68/92/73/new_gf10.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Air_bu10](https://i.servimg.com/u/f19/12/68/92/73/air_bu10.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Instal15](https://i.servimg.com/u/f19/12/68/92/73/instal15.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Instal14](https://i.servimg.com/u/f19/12/68/92/73/instal14.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Instal16](https://i.servimg.com/u/f19/12/68/92/73/instal16.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Barely10](https://i.servimg.com/u/f19/12/68/92/73/barely10.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Hood_c10](https://i.servimg.com/u/f19/12/68/92/73/hood_c10.jpg)
Well had some nice weather some got some Progress done
1. Installed throttle bracket and cable just have to get the kickdown on the trans whenever the new cable gets here 5 weeks and counting.
2. Did a test run on the Vinyl I am gonna be using for after the repaint... testing UV and longevity of the Vinyl.
3. Today I pulled the dash and got the Digital Gauges mounted up in the dash all I have to do is wire the gauges.
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 42548210](https://i.servimg.com/u/f19/12/68/92/73/42548210.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 42549010](https://i.servimg.com/u/f19/12/68/92/73/42549010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 42549110](https://i.servimg.com/u/f19/12/68/92/73/42549110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 1_old_12](https://i.servimg.com/u/f19/12/68/92/73/1_old_12.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 1_old_10](https://i.servimg.com/u/f19/12/68/92/73/1_old_10.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 1_old_11](https://i.servimg.com/u/f19/12/68/92/73/1_old_11.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 41612110](https://i.servimg.com/u/f19/12/68/92/73/41612110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 42056110](https://i.servimg.com/u/f19/12/68/92/73/42056110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 42303610](https://i.servimg.com/u/f19/12/68/92/73/42303610.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 41125510](https://i.servimg.com/u/f19/12/68/92/73/41125510.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Prd_ss11](https://i.servimg.com/u/f19/12/68/92/73/prd_ss11.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Prd_ss10](https://i.servimg.com/u/f19/12/68/92/73/prd_ss10.jpg)
I also had an Issue with some supposed NOS hood hinges someone just painted them to look that way and creased the Hood So the One I found I have to transfer the Pattern over to the new to me hood......
The X marks the spot where I am cutting it off to make the stinger scoop functional
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43101310](https://i.servimg.com/u/f19/12/68/92/73/43101310.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43133810](https://i.servimg.com/u/f19/12/68/92/73/43133810.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43142110](https://i.servimg.com/u/f19/12/68/92/73/43142110.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43085610](https://i.servimg.com/u/f19/12/68/92/73/43085610.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 Hood_d10](https://i.servimg.com/u/f19/12/68/92/73/hood_d10.jpg)
I also put the Turbines Back on I really like these wheels sooooo much I need one more tire 255/60 for Drive side other than that They Cleaned up well 120 then 220 then 400 then used alum brightener to make them look 25% presentable LOL
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43088610](https://i.servimg.com/u/f19/12/68/92/73/43088610.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43090010](https://i.servimg.com/u/f19/12/68/92/73/43090010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43099210](https://i.servimg.com/u/f19/12/68/92/73/43099210.jpg)
So now Ev1 is up to date with whats been happening I have been working on the SE alot to help and so far so good
when you mess up that hood cutting it, I do have an extra original hood!
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 1f60e](https://2img.net/i/fa/twemoji/16x16/1f60e.png)
Iggy- G3GM Member
Iggy wrote:when you mess up that hood cutting it, I do have an extra original hood!![]()
Been Planning on this cut for quite some time and have everything needed to make a it a smooth as Possible transition and will have a trim piece covering the cut circle (kinda like a door edge guard) and I am gonna Add the Hood Insulation also, The self etching is just i Case I break thru to metal on Top side and around where the hole is Cut
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43097410](https://i.servimg.com/u/f19/12/68/92/73/43097410.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43127010](https://i.servimg.com/u/f19/12/68/92/73/43127010.jpg)
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 43200910](https://i.servimg.com/u/f19/12/68/92/73/43200910.jpg)
Iggy and 76Chevelle2Tone like this post
Good luck with the hood. but I am a bit concerned about the rear wheel well rust around the edges. Are you going to need to cut and weld fresh metal to it?
I have 100% rust free quarters taken of another car prepped and ready to use Will just cut off ONLY what I need to use, I have them for both sides but wont tackle them till I get the floors taken car of that Came from the Original owners Loader.
The Transporter could not get to the area where this one was So they (Original Owner) had to use a Loader to put it on the trailer and did that Mangle damage I have the fender to replace the font one where they did the damage at same time as well
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 36839510](https://i.servimg.com/u/f19/12/68/92/73/36839510.jpg)
The quarters I have were removed from the 73 tail panel in Pic they were cut off at doors all the way back, and yes my friend Modded a 73 tail panel onto a 77 Chevelle
![Rusty's progress Carpet Chevk now onto floor replacement - Page 10 1quart10](https://i.servimg.com/u/f19/12/68/92/73/1quart10.jpg)
I'll just throw this out there from a body work standpoint. Don't be afraid to replace more than you need. replace more than you have to if it will make the seam less visible and smaller. For example if you replace the whole quarter, you can seam it on a corner, or up on the B pillar rather than a long seam down the middle of the entire panel because you only needed the bottom.
Joe73 likes this post
Page 10 of 12
» Ebay 4 door 73 parts
» Battery - Will Group 78 fit stock batter tray?
» Welcome abaord ElcaminoPasztor
» Four Door/Wagon Bucket Seats
» 2024 HOT ROD Power Tour Story on MSN
