Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS?
G3GM :: G3 Tech :: Electrical
The dome lamp harness in my '76 GMC Sprint has been splice repaired multiple times, become unreliable again, and I have elected to totally replace it. I sourced a new reproduction lamp assembly with pigtails, and also got some new white 18ga primary wire to run down to the connection on the driver's side floor.
Attached are pics of the GM PACK-CON II connector body and two terminals that go into it. I have not been able to find these terminals ANYWHERE and also cannot locate a part # for them, despite having the GM parts book for 71-77 Sprint. I ordered in some similar terminals at the local parts store, but they will not retain properly in the connector body.
Does anybody have any leads on where to source these terminals? Any help would be appreciated....as I'm running out of steam on this.![Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS? Img_7611](https://i.servimg.com/u/f86/19/60/13/47/img_7611.jpg)
![Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS? Img_7612](https://i.servimg.com/u/f86/19/60/13/47/img_7612.jpg)
![Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS? Img_7610](https://i.servimg.com/u/f86/19/60/13/47/img_7610.jpg)
relic7680- G3GM Member
Re: Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS?
Hey. I completely re-wired my Laguna a few years ago. In the morning I will go to my storage house and see if I can find something that looks like that. I also have some pieces left over from my Painless kit. They might have one of those connectors in there. I will let you know by later tomorrow.
May want to look into Mouser.com and search in the automotive terminals section if you know the part number of that particular terminal.
Otherwise you will have to seek by picture......and that could take a considerable amount of time.
impalamonte- G3GM Enthusiast
I just went through Mouser.com, and also went to the Aptiv (formerly Delphi) catalog of terminals. These were the most extensive listings I have seen so far.
However, there seems to be a lack of availability for the PACK-CON II terminals. PACK-CON I & III are available. The only thing Mouser listed for II was the plastic connector body.
Hey. I am striking out so far. I have another place to look in the morning.
I believe this plug uses the same type terminal that is in your dome light harness. You could de-pin these and pop them into your original plug housing.
https://www.ebay.com/itm/266803913031?epid=1027049589&itmmeta=01J1RQ9AMP479FR5S9V57BDDAZ&hash=item3e1ec0a147:g:J5UAAOSwcWhmPEtz&itmprp=enc%3AAQAJAAAA4GHUnlRiyow9K%2FxdRjtMKzqUUw0EZDO1ugELnGJ4%2FjENKcQuulNo--W6KVZplx2uZIrqOoRv7bo5jhDKrox4mt4mKTOkXnizde796u2wkAPeaqFnwZT%2FqAG5%2Bgk9JMYCGR7qrXKDmx65Jy8%2FErUgJliqryQBsnomnZvvMBIUExmPZqT4mAz%2F8Ovebrsmuatf2AozkA7mAKqzRJ74jwTSQgQaxK1ZKgJbjx8CtFkItfnMGr7mjGk9%2BbzkMUbpEpl7s%2B1Mjs7gLw95vZe4uPBYLmrSlB19MCOOyY2KkUP%2FNXwm%7Ctkp%3ABk9SR7iqpZeOZA
- Street Cred : 35
This also may work with a little modification.
https://www.ebay.com/itm/266453913257?itmmeta=01J1RR60F676G5TWH789FNSH5X&hash=item3e09e40ea9:g:aQEAAOSwZTZlKXEZ&itmprp=enc%3AAQAJAAAA4LXzVGO5h5VvDbRdQW5nIBb93PjP2l2eqdlzUC1yynbn2KWaF1rvDx3b9wwrrZFgAi4vYDOYgXN3KuXF9mNDSwvcgp93eg1KW0BgtcXuBuqKH4%2BOi2lh8opizZTjT3kkmeWw0ykDuJEhk3k2j1jXKiZt8NqJC13Y%2BhsS0%2FtHy790eUW6d0XPsbVTqIENy8ZkqOymUfZrInf3cjBHU259f2Gt70HU0HJE8JoE0zsW5mNWZW0AJ7547vofR8kcLK3E4SqFJjcZRcXoitfgVhN3%2B12SgjrNQ%2F4JjOjj2xLqnmog%7Ctkp%3ABFBM1IeYmI5k
- Street Cred : 35
Third time is a charm. This one looks to be correct.
https://prairiebearingshop.com/10-pc-16-14-awg-gm-pack-con-type-2-unsealed-female-terminal-147-bp/
- Street Cred : 35
The last post is as close as I've come...terminals are very similar to the defunct Dorman ones I saw in a paper catalog at O'Reilly yesterday. Problems are that they're 16-14ga instead of 18ga, and I'm not even sure I can source them anymore from the looks of it.
I could always step up my harness gauge to 16 and hopefully use my heat shrink bullet connectors to drop back to 18 for the lamp side pigtails. Gotta dig some more....
Thanks fellas.
Thanks fellas.
https://www.summitracing.com/parts/pco-5803pt
impalamonte wrote:https://www.summitracing.com/parts/pco-5803pt
Yeah, that's the PACK-CON I terminal....ordered some locally and found out that they don't retain in the connector body properly.
g3chevy / Mr Pontiac wrote:Third time is a charm. This one looks to be correct.
These are no longer offered by the supplier, PICO.
relic7680 wrote:g3chevy / Mr Pontiac wrote:Third time is a charm. This one looks to be correct.
Figures....and those looked to be an almost exact replacement. Maybe you could use a different design plug and create a new harness from terminals like these?
![Rebuilding 76 Sprint Dome Lamp Harness...ANYBODY HAVE THESE TERMINALS? Electr10](https://i.servimg.com/u/f59/20/30/29/07/electr10.jpg)
- Street Cred : 35
g3chevy / Mr Pontiac wrote:relic7680 wrote:g3chevy / Mr Pontiac wrote:Third time is a charm. This one looks to be correct.
I really don't want to cut/alter the car side harness....gotta keep looking.
Not sure if this would work. It appears to have a different plug/terminal housing but you may be able to de-pin it and use your original.
https://www.ebay.com/itm/225243903375?itmmeta=01J1RPKNT7Y2HCNXN5YXY88Y9Y&hash=item347195358f:g:F-AAAOSw2Ylja983&itmprp=enc%3AAQAJAAAA0IMlq0MrKB%2BeL7e8ESWR9z8499kE0MSKOV6Z%2B9MJvFujTBx2ABsIH56Z4%2FIe1Fd2HAp08Jl%2FB4qAamKO6sZJmT5ZYb7lV5%2BOJgWoe%2Bo4ZjyfJLvg6V1PC1Fa0O9olQF%2B8%2BoxgD3I2rgu0MetaT5o62uD35zYwTBCGhC1PkB%2BhNR7KWZB8SdBp4zCJ3BqQXjATZGhKDIOduU62md2JOM0i3Ta0vgn%2FqzhNIhftk3mq%2FsamiRTbsfm6AcY0bcNd1eLCSjEmxnFJNKIu9dTlVLeCmM%3D%7Ctkp%3ABk9SR5jdzpaOZA
- Street Cred : 35
g3chevy / Mr Pontiac wrote:Not sure if this would work. It appears to have a different plug/terminal housing but you may be able to de-pin it and use your original.
Looks like the Malibu applications had a different style of connector.....although I wish I could look at one of those to see exactly what they did.
» GEN cluster lamp stays ON with ignition OFF
» rebuilding door hinges
» Need wire diagram for headlight, dash lights and dome light
» HAPPY 7-3 POST YOUR 73's
» Ebay 4 door 73 parts
» Battery - Will Group 78 fit stock batter tray?
» Welcome abaord ElcaminoPasztor
» Four Door/Wagon Bucket Seats
