dash light question
+4
mikei1253
8 posters
G3GM :: G3 Tech :: Electrical
dash light question
when i turn on my headlights my gauge lights dont come on non of them. it used to be intermittent when it would do this but now its constant. any suggestions on where to start or is there a common issue with these cars maybe? just tryin to get a good idea where to start out before i start ripping into it
mikei1253- G3GM Newbie
Re: dash light question
Three most common issues:
1. blown fuse
2. bad headlight switch (dimmer circuit)
3. melted the printed circuit behind the cluster that powers the lights
really dont like the 3rd one so lets hope for #2 lol
I know this is a stupid answer, but try turning the headlights knob counter clockwise and then all the way clockwise. I have seen some older cars work this way. JB
The headlight switch has a rheostat built into it, that is rotated by the light switch knob. It's highly likely that the rheostat is failing...IE the windings on it are falling apart. Changing the headlight switch would likely solve the problem......OR.....the connector on the center instrument cluster that feeds the printed circuit for lights & gauges etc, needs to be cleaned up.
That's what my experience has been anyway...
Same situation. No dash lights at all. I think something in the switch is bad on mine. I had some burned out bulbs and replaced a few, but none seem to work.
I think maybe the turn signal ones work, not sure.
Bad switch is common considering the age of our cars and the fact that all the headlight juice runs directly through the switch instead of a relay. Easy to replace, so no real reason not to after 40 years.
X2 on the headlight switch. I'll bet money on it!
Bruisr- G3GM Member
The headlight switch was the culprit on mine when it was doing that. They are cheap and easy to change too.
WyldeBill66- G3GM Member
Twice in my life I've had that problem on older cars. Both times the switch fixed it. Try turning the knob slowly and seeing if the lights come on (or at least flicker) if they do replace the switch.
» Dash light not lighting
» Need wire diagram for headlight, dash lights and dome light
» ss dash question
» ss dash question
Today at 12:44 am by Mcarlo77
Today at 12:31 am by Limey SE
» fuel gauge malfunction?
Thu Oct 03, 2024 5:44 pm by 76Chevelle2Tone
» Chevelle Power Trunk Release
Tue Oct 01, 2024 11:54 am by Mcarlo77
» G3 Chevy rims- help ID these
Mon Sep 30, 2024 12:49 am by Limey SE
» Buckskin vinyl washout
Thu Sep 26, 2024 10:43 am by Mcarlo77
» You know I love a good bike
Thu Sep 26, 2024 6:22 am by Finn Monte
» MONTE FRONT BUMPER TUCK
Tue Sep 24, 2024 11:55 am by Finn Monte
» Life & Back On The Radio
Sat Sep 21, 2024 10:15 am by Limey SE
» Tips for Dash Removal?
Fri Sep 20, 2024 5:42 pm by 73 ss wgn
