Dash light not lighting
2 posters
G3GM :: G3 Tech :: Electrical
Any of you guys ever have the dash turn signal indicators stop working? Both aren't working on the dash they blink fine outside but no little green light also the dash lights on the left do not illuminate. I replaced the bulbs with correct 168 bulbs still nothing.
Re: Dash light not lighting
Did they all go out at the same time? I know those cheap-A$$ sockets can be finicky after all these years...but, seems odd that at least one didn't come back to life when replacing the bulbs just from wiggling them if that was the problem. I've got one blinker bulb on the 'Guna that goes out...I remove the bezel and wiggle it and voila, it comes back on...only to go out again later. Just haven't been ambitious enough to remove the cluster and replace the socket.
- Street Cred : 78
The right side one started working the left do sent and the little pod with the oil and temp doesn't either. I'm going to mess with it more tonight. I hope it's not that printed circut in back of the gauges. Looks like a pain in the A$$ to get out
Willing to bet it's the light sockets giving you problems and not the flex circuit. With your key ON, wiggle the new bulbs you installed and see if they don't light. If so, you'll probably want to replace the sockets and that will require you to remove the cluster to access them.
- Street Cred : 78
Mcarlo77 wrote:Did they all go out at the same time? I know those cheap-A$$ sockets can be finicky after all these years...but, seems odd that at least one didn't come back to life when replacing the bulbs just from wiggling them if that was the problem. I've got one blinker bulb on the 'Guna that goes out...I remove the bezel and wiggle it and voila, it comes back on...only to go out again later. Just haven't been ambitious enough to remove the cluster and replace the socket.
Happy to report that it was indeed those sockets!. I scraped at them a little and bent them in a little and they started working!
Today at 10:41 am by Mcarlo77
Today at 9:51 am by g3chevy / Mr Pontiac
» 73 laguna trim
Today at 12:44 am by Mcarlo77
» fuel gauge malfunction?
Thu Oct 03, 2024 5:44 pm by 76Chevelle2Tone
» G3 Chevy rims- help ID these
Mon Sep 30, 2024 12:49 am by Limey SE
» Buckskin vinyl washout
Thu Sep 26, 2024 10:43 am by Mcarlo77
» You know I love a good bike
Thu Sep 26, 2024 6:22 am by Finn Monte
» MONTE FRONT BUMPER TUCK
Tue Sep 24, 2024 11:55 am by Finn Monte
» Life & Back On The Radio
Sat Sep 21, 2024 10:15 am by Limey SE
» Tips for Dash Removal?
Fri Sep 20, 2024 5:42 pm by 73 ss wgn
