rebuilding door hinges
I rebuilt the door hinges for my El Camino project. The usual pin & bushings of course, but I needed to do the roller that engages the spring-loaded detent to hold the door open.
With the spring removed, I discovered that the shaft that the roller runs on, is pressed in place, and it has splines on it. Clamping the shaft in the vice, I tapped the hinge to remove the splined shaft.
Then I found that the hole the shaft was pressed into, was the right size for a 5/16-24 tap, so I tapped the hole, and used a bolt with an un-threaded shank that was the correct amount for a bushing, which the roller will run on. I used an aircraft bolt, since I have those in stock.
Anyway, just a bit of info for anyone who may want to re-do door hinges.....
Re: rebuilding door hinges
ok now I will you send you mine to do and you keep them, then you send me yours that are done LOL No really
@ Limey. Good info! I'll add this to the 1,000,000 things left to do on my car
DiscoMalibu- G3GM Member
Don't suppose there might be a photo or two of that?
i just found my rollers were shot,but still working.
so i found a pass,side but had to replace the pin and bushing.but the roller was near new.
the driver i found needed nothing,roller looked new also.
Here's a pic. did I ever tell ya I like red ?
Thanks. My bushings are in decent shape, but my passenger door is actually missing the detent pin altogether, so this info will come in handy when I eventually get to that point.
» door hinges
» Rebuillding my door hinges
» Trade NOS A-body trunk lid hinges for 1974 Monte Carlo trunk lid hinges.
Today at 7:05 pm by Limey SE
» Happy 7-6 post them up
Today at 8:28 am by 76 Malibu
» A/C wire Harness
Yesterday at 11:08 pm by 76Chevelle2Tone
Thu Jul 04, 2024 11:17 pm by 76 Malibu
» HAPPY 7-4 POST THEM UP
Thu Jul 04, 2024 7:06 pm by Keith Seymore
» HAPPY 7-3 POST YOUR 73's
Thu Jul 04, 2024 9:39 am by 73ss
Tue Jul 02, 2024 2:03 pm by jpowen49
Tue Jul 02, 2024 11:47 am by Limey SE
Thu Jun 27, 2024 7:50 pm by Limey SE
Thu Jun 27, 2024 7:43 pm by Limey SE
