bench test clock
G3GM :: G3 Tech :: Electrical
Re: bench test clock
Talk about serendipity; Just last weekend, I swapped the clock in my Monte Carlo with one of the rebuilt clocks I have on my shelf.
The answer to your question is "Yes" but it's better if you open it up so you can see if the solenoid is fried. Even if it's not fried, it may not work for various other reasons.
If you're squeamish or reluctant to open the clock, do a rudimentary continuity test across the two terminals using a meter, NOT a 12V light.
If there's no continuity, there are two reasons; the solenoid is fried (most likely), the mechanism is dirty and needs service.
If there is continuity then using a 12V power source, attach ground "-" to one terminal then momentarily touch the positive "+" to the other terminal. You should see a spark and hear a light "thud" as the solenoid engages to wind the spring. If you don't hear a "thud", DO NOT try to energize the solenoid again, prepare yourself to open the clock.
If it made the "thud" sound and everything is ok, the clock should start ticking. If it doesn't, test for continuity again. If the meter shows the circuit is closed, you'll need to open the clock. If the circuit is open, try twisting the clock. What that means is grasp the clock in your hand like you would a door knob then quickly twist your hand/wrist, like you would a door knob, back and forth a couple of times. That helps the flywheel inside the clock to get started turning. If it doesn't start working after that, you'll need to open the clock.
zucchi- G3GM Member
jpowen49 likes this post
I've opened up several dozen of these...no big deal. Remove the hands by lifting straight up. Then, straighten the tabs on the clock face so it can be lifted exposing several crimped tabs (you can see one of them below the adjuster knob in your photo). Straighten those and lift the inner works out of the shell. If that clock hasn't run in a long while, I doubt it will start when putting voltage to it. And yes, you can hook 12V to it without any problem. So, as Zucchi mentioned, first thing to do after opening it up is to look at the coils. It will be obvious if they are burnt. Can also look closely to see if one of the wires coming off the coils is broken. Either one is a sign it's shot.
If both look good, squirt a little light machine oil (do not recommend using WD40; although for testing purposes, it works fine) on the gears, manually wind the mechanism and give the little flywheel a flick and see if it continues to unwind on it's own. May take a couple of tries to get all the parts loosened up. Lastly, put power to it and see if it works on it's own. If so, put it all back together and should be fine for a year or two before it needs to be lubed again.
P.S. Little known fact, the coils can be replaced/swapped if done carefully...and, if you can find a good replacement. I just refurbished a clock for my Monte using the coil from a NOS Chevelle clock. Found the clock on e-Bay for less than $30 earlier this year.
I just finished recording a video on this topic. I expect to publish it on YouTube this coming Monday.
zucchi- G3GM Member
Thank you both zucchi and Mcarlo77 for taking the time to help me. I followed your instructions and was successful in getting the clock running, thank you so much.
No continuity so I opened it up as instructed. The coils looked good but the points were stuck open. I sprayed the works with electrical contact cleaner and the points closed on there on. I checked for continuity again and it was good so I connected it to a battery. To my surprise it started running. A few pictures for anyone who hasn`t opened one up. zucchi can you post a link to your YouTube channel. Thank you both again.
jpowen49- G3GM Member
Thanks for the info in this thread. Does the larger clock used on the horizontal speedometer dash use the same internals as this clock? I bought a used clock and it doesn't work. A few restoration shops said they won't restore that type of clock, so maybe I will try to do it myself. It doesn't look too bad.
76 Malibu- G3GM Member
Here's the video:
It's also in my signature as "Drive your old car forever"
Certainly: https://www.youtube.com/channel/UC-q-c4ylQUn6PXiQu9HZiOQ/jpowen49 wrote:zucchi can you post a link to your YouTube channel.
zucchi- G3GM Member
zucchi wrote:Here's the video:Certainly: https://www.youtube.com/channel/UC-q-c4ylQUn6PXiQu9HZiOQ/jpowen49 wrote:zucchi can you post a link to your YouTube channel.
Do you know if the workings of the larger clock used on Malibus with the horizontal speedometer dash will be the same as this round dash clock? I'd like to work on mine, but not sure if it is a complete different design or not.
GM used two manufacturers during the 1970s; Borg Instruments and Westclox, a.k.a. General Time or G.T. Corp.; your clock will be one of these.76 Malibu wrote:Do you know if the workings of the larger clock used on Malibus with the horizontal speedometer dash will be the same as this round dash clock?
The clock assemblies are interchangeable but their internal parts are not. The G.T. Corp. clocks feature a dual wound solenoid whereas he Borg clocks have a single wound solenoid. The clock in the video is a G.T. Corp clock. The link below goes to an article about repairing a Borg clock: https://www.oldcarsweekly.com/features/putting-the-ticktock-back-in-your-old-car-clock-rehab
zucchi- G3GM Member
76 Malibu likes this post
I just pull my clock off the shelf, it says GT corp on it. Thanks, it sounds like I got a new project to work on.
» i might need my clock cleaned!
» Clock Delete? 73 SS 350 on Ebay
Today at 17:08 by 76Chevelle2Tone
» Tips for Dash Removal?
Today at 13:26 by Limey SE
Yesterday at 22:13 by bracketchev1221
Fri 13 Sep 2024 - 15:04 by 73 ss wgn
Fri 13 Sep 2024 - 11:23 by Limey SE
» 1973 Chevelle Parts
Thu 12 Sep 2024 - 21:30 by 76 Malibu
Wed 11 Sep 2024 - 8:53 by dhw3971
» R.I.P. James Earl Jones
Tue 10 Sep 2024 - 11:12 by 76Chevelle2Tone
» Rusty's progress RUT ROH Dakota Dash is Next oh myyy lawwwwdddd LOL
Mon 9 Sep 2024 - 19:29 by Limey SE
Mon 9 Sep 2024 - 18:58 by Limey SE
