8.5" 28 Spline Detroit Locker VS. GM 3 Series Posi for 80s Build
2 posters
I am wanting to get a posi or locker unit for the 8.5" 28 spline 10 bolt rear in my '76 GMC Sprint. The car is being built as a period mid 80s street machine and will have a 3.42:1 ratio with 275/60R15 rear tires. It already has Yukon 28 spline replacement axles and a freshly built TH350 is in front of it. The car WILL have a 425-450hp 406 small block (currently a mild 9:1 355).
I am considering some 3 series GM posi units on ebay here:
https://www.ebay.com/itm/235263577331
https://www.ebay.com/itm/154649352539
The second listing proclaims to be a stronger design.
I am also considering Detroit Locker part # 187C149A, which sells new from Summit for $1000+. Was a Detroit Locker for my 10 bolt available back in the 80s? How many guys were running them on the street? What are the pros and cons of this setup versus the GM posi units?
I am honestly not very knowledgeable on this topic, though I have done some research. Any help from guys who were running this stuff back in the day would be very appreciated.
relic7680- G3GM Member
Re: 8.5" 28 Spline Detroit Locker VS. GM 3 Series Posi for 80s Build
In the 80’s there was the gm/eaton posi or the Detroit locker. The locker was noisy and rough. But it was stronger and didn’t slip. You could get a higher spring pressure Eaton that would be fine for anything you throw at it on the street.
relic7680 likes this post
» POWERTRAX No slip, Lock Right, Detroit EZ Locker or other Lunch box lockers
» 30 spline carrier
» steering column spline count
» 30 spline carrier
Yesterday at 12:42 pm by zucchi
» Weld Rodlite/Hoosiers for sale
Yesterday at 11:15 am by Rocketman269V
» Things are looking up
Sun Sep 15, 2024 6:08 pm by 76Chevelle2Tone
» Tips for Dash Removal?
Sun Sep 15, 2024 2:26 pm by Limey SE
» 1973 Chevelle Parts
» R.I.P. James Earl Jones
Tue Sep 10, 2024 12:12 pm by 76Chevelle2Tone
