Monte Carlo 76-77 clear front turn lights vs 74 ElCamino
builtnotbought
I'm interested in interchangiability of Monte Carlo 76-77 white clear front turn signals in bumper vs 74 Elcamino yellow ones?
![Monte Carlo 76-77 clear front turn lights vs 74 ElCamino 77mont10](https://i.servimg.com/u/f68/19/38/48/10/77mont10.jpg)
![Monte Carlo 76-77 clear front turn lights vs 74 ElCamino 77mont11](https://i.servimg.com/u/f68/19/38/48/10/77mont11.jpg)
vs
![Monte Carlo 76-77 clear front turn lights vs 74 ElCamino 1974el10](https://i.servimg.com/u/f68/19/38/48/10/1974el10.jpg)
76-77 Montecarlo lense looks similar to 1973 El camino
Thank you
vs
Thank you
builtnotbought- G3GM Member
Re: Monte Carlo 76-77 clear front turn lights vs 74 ElCamino
Anyone know if the Monte Carlo lenses will work in the Chevelle bumper?
Hawk03- G3GM Enthusiast
I don't have a definitive answer for you. But, I can tell you the Monte turn signal opening in the bumper is about 7" wide x 2 1/8" tall.
Thanks Steve. I will measure the chevelle ones to see if they are close. I searched OPGI for new Monte housings and they are not available but they are for the chevelles, although they do not give the dimensions.
Looks to me like the Monte Carlo lens would be flat compared to the Chevelle lens where it meets the bumper. That would make the Monte lens face down if installed in the Chevelle.
Yeah...good point. I seriously doubt the two are interchangeable.
Ah shoot, I didn't even realize they mounted differently. I doubt they will fit either. I was looking at the size and not how they mounted.
Monte Carlo turn signals in 1977 Chevelle SE Bumper
What kind of modification did you have to do to make them fit Limey?
you can do it one of two ways
Trace the yellow one's mounting holes onto cardboard template, then transfer that to the Monte Carlo turn signal and trim where needed the Monte Carlo is a little deeper in
Second option which I found super easy get the heat gun out to loosen the adhesive backing on the Monte Carlo Bezel and Malibu Bezel and they come off reglue them and silicone them to keep water out and done
Got it done in about 90 minutes time total, Oviously have to change to a Yellow Bulb here In Illinois I dont know your areas regulations for turn signals Jeff you maybe could get away with Clear where your at Since Some newer cars use a Clear front one anyways
Thanks for the tips Limey. Now I just have to find a good pair of clear ones. haha
Limey SE likes this post
Nick Wellik and Jason Fuller Sr on Face book have a mess of them Jason is preferred seller for me, he is friends with John Murtaugh aka Dynchel is his name here
