engine swap Chevy to ??
So I've had my feel with my 350 no more money into this thing, it be another 800 just to see what's wrong and not guarantee to be running, so im looking at new options I want my car to be different sense it's stripped down completely, I was thinking of doing a 351, 460, 381,440 do they make adaptors for any of these and what chassis can I relate my car to aka Camaro, elk, Monte,etc. Just food for thought.
thepossumface- G3GM Member
Re: engine swap Chevy to ??
I wouldnt bother. The chevy 350 is the best all around engine. Its used in all types of equipment, boats, etc. You can build it for torque, hp, rpm's or anything. And parts are by far easier to get and usually cheaper. It also responds to upgrades really well. I'd take a look around on ebay and buy a complete kit to redo the engine. It'll run you less than 1000 bucks. And even cheaper if you reuse your crank. Real easy to get 350+ hp out of the engine.
Switching to other makes involves mounting issues, adapter plates, driveshaft mods. Chevy small blocks definitely make nice power on the cheap and can scream some nice rpms.
Just my thought. Save the headaches.
I agree with Joe73. I started down the same road when I decided that the 305 just wan't cutting it. Not to mention it needed a valve job and a cam. I looked at all the options, including rebuilding the 305 (not an option) I opted to get a 350 from a friend's friend ($100) spent about $500 at the macine shop. Bored 30 over. crank polished 10 & 10. Got a kit from Northern Auto Parts.
http://www.northernautoparts.com/
with the Chevy LT1 cam I wanted, included all gaskets, seals timing gear, rings, pistons and more, was about $300, shipped. The come with 0/10/20/30 thou sized pistons / rings all at the same cost.
I found a used aluminum Edelbrock Performer intake for $50, got it blasted and clear coated.
Instead of dealing wiht the POS heads on the 4bolt truck block I bought kept my eyes open and got a pair of redone older race heads (cast iron) with new springs etc, stainless valves for about $500 which was less than having the ones I had reworked, never mind the springs and valves.
The kids wanted bling, so we got a chrome dress up kit, but not needed, reused alternator, water pump etc off the 305.
Re-used the q-jet I'd rebuilt the year before and away we went.
Not much more than $1400, but if you don't need the machine work then you're in that $1000 ball park.
Not to mentin I've got exactly what I wanted from the engine from the start.
Dinomyte- Donating Member
Just pull it and rebuild it. I just got a 350 4 bolt block, to build a 383 for mine. I was thinking about a 454 but decided against it.
Stick with something by GM, anything. For ultra coolness go with a Chevy W engine. 348 or 409. They are getting hard to find, but aftermarket blocks are available now and at least one natiomaly known shop specializes in them. I also usually advise getting a crate engine. Two of the best choices are the 383 truck engine and the 454 HP, 454 Cube engine, both by GM Performance parts. JB
I want a 383. If anyone one wants to donate one and have it shipped to me just pm me for my address. ![Smile](https://2img.net/i/fa/i/smiles/icon_smile.gif)
Summit kit with pistons, 30 over for $237
http://www.summitracing.com/parts/sum-sbckit1-033/overview/make/chevrolet/year/1976/model/laguna
Sealed power kit for $370
http://www.summitracing.com/parts/fem-mhp134-332/overview/make/chevrolet/year/1976/model/laguna
And they have every configuration of undersizes and oversizes. Boil and bore the block, check and polish the crank. An intake and carb or maybe some headwork and your good to go.
Very reasonable to build a small block chevy for some nice power.
Yeah true , but im a Ford guy, and I've had one prob after another with this engine, and getting to the point to I'm not throwing anymore money at all, but buying a new crate motor is off the list, and on top of having to rewire, and so forth, it was just an idea but the more i think of it the more id rather let it just sit lol dumped 2500 into it and it's a mess lol
» Wild 1977 Pro Touring-Style Chevy Monte Carlo-Super Chevy
» Pontiac in a chevy? Swap questions
» 1974 Monte Carlo engine & engine bay restoration.
