Choice of carburator
lars
Colonnade Mattie
I need a new one, and was wondering what you guys would say is the best choice. I'd prefer it to be easy to bolt on.
Everything is essentially stock, and I have the two-barrel manifold, with the 305 v8.
lars wrote:here is the engine ...
lars- G3GM Member
Re: Choice of carburator
If you don't need to drive the car every day maybe take the carb off and try to rebuilt it. A kit and carb cleaner would be about 30 bucks..not hard to do and might be best bet for that.
Colonnade Mattie- G3GM Member
I considered it, but I'm away at college most of the time, and when I will need it during the winter break I'll need it every day and for it to be as reliable as it has been.
I'm not experienced, but I feel like it should be replaced. The choke plate doesn't move unless moved by hand, and it stalls occasionally. I've also heard that a new aftermarket one will both perform better and give better mileage. (Not like it's really a big deal)
lars- G3GM Member
Idk how many choices are out there if a stock replacement aftermarket 2 bbl carb. Could you pull it and send it out(to be rebuilt) while you are at school? Any aftermarket carb I've ever dealt with required some "custom" mods for fuel line, choke, etc.
I had my Q jet rebuilt by Hobbs carburetor.
108 Windham Rd, Pelham, NH 03076
(603) 635-2415
Only cost about $100.
(603) 635-2415
There's a place called Mountain Man Carbs, that could rebuild it for you. They have a very good reputation.
Here's a phone number....(479)639-2022 His wife may answer when you call...good folks..
Changing carbs is gonna be more work than I believe you want at this point.....
Hope some of this helps...
Bill
Bill
If you want an aftermarket carb I think you should use a 4-barrel and an intake manifold too.
Or just rebuild the stock carb.
Engine has run great with this carb before, maybe it only needs some adjustment of the choke?
Spang- G3GM Newbie
