HELPPPP someone with this bolt/rod?
OKay so i was turning the motor over oil pump down and some rod thing fell out the motor as i was turniing it were does it go?
i remember seeing one at the front of the camshaft but i have no idea oh how to get in back in or what i need to do any help?
thepossumface- G3GM Member
Re: HELPPPP someone with this bolt/rod?
Sounds like fuel pump rod -- rides on the cam and pushed the fuel pump lever. Goes back into a slot up front inside the fuel pump mounting boss.
when you o to reinstall the fuel pump push rod, there is a bolt boss on the front of the block, (the top hole) is threaded all the way thru. Find a bolt about 1 1/2-2 inches long and thread into hole without tools, this is used to keep fuel push rod in place when replacing fuel pump! Be sure to remove before starting engine, and use a 3/4 inch bolt with thread sealant to protect against oil leaks.
Bruisr- G3GM Member
yea it was my fuel rod, i todally forgot about it haha had a stupid moment
Make sure to put it back in with the polished end (top) toward the cam, where it's mated. You will notice witness marks on the other end (bottom) from the pump arm.
yeah i got it in right thanks yall
» Are the new '120mm' 5 bolt wheels equal to 4.75" 5 bolt older style wheels?
» 350 4-Bolt
» Anybody put a '68-72 12 bolt rear end in a 73-77?
» 350 4-Bolt
