From the weeds to the wicked! (73 Chevelle)
+11
alleyball4
badtemper44
Fishgrinder
fishhead
15 posters
Page 2 of 3
Page 2 of 3 • 1, 2, 3
Re: From the weeds to the wicked! (73 Chevelle)
Could just not connect the lights on the Bigger ones and then add just a little LED light right above them, just enough so you can read them ....
Make sure to take lots of pics as I will need reference when tackling my dash. I plan on either reworking one that has the round gauges in it or make my own. Kinda leaning toward the second option and no idea where to start.
Dive right in is the plan!
Yeah I will definitely keep progressive photos coming.
First off, I sort of regret tearing the old padding out of the dash pad as extensively as I did, because I could have just sanded away were it was cracked and added an epoxy filler to sand out. But with that being said, I almost had no choice but to do it this way because I needed to see what I had to cut through for the tablet slot.
I did however leave the front edges of the dash padding in tact so I would not have to reshape the beveled edging from scratch. I will post pics up soon to show what I mean.
The new vinyl I bought is really nice stuff though, and it has a nice elasticity to it that should provide very helpful for stretching the new material around the complex curves.
I am not sure what I am going to do with the lower plastic dash half yet. I thought about either painting it or just vinyl wrapping it as well.
Tuffenough4u- G3GM Member
Did you get marine quality vinyl? Just wondering cause it usually has better elasticity for those curves your talking about.
This is what I purchased
http://www.onlinefabricstore.net/vinyl-fabric/faux-leather-vinyl-fabric/symphony-classic-black-faux-leather-vinyl-fabric-.htm
Material: 100% Vinyl
Width: 54"
Weight: 29 Ounces per Linear Yard
Thickness: 1.2 mm
Backing: 100% Polyester
Suggested Uses: Automotive, Contract, Education, Healthcare, Hospitality, Marine/Outdoor, Residential, RV
Performance Specifications:
Abrasion Resistance: 500,000+ Double Rubs per ASTM D 4157-10 / CFFA-1A
Ultra Violet Resistance: 1000 Hours ASTM G154-06 &AATCC 16-2004, Option 3
Cold Crack: -20 degrees F CFFA-6 Federal Standard No. 191A-Method 5874
Mildew Resistant: CFFA-120 / ASTM G21-96Anti-Bacterial: CFFA-300 / AATCC Test Method 147-1998
Anti-Microbial: CFFA-300 / AATCC Test Method 147-1998
Resilience SR: Yes
Bleach Resistant: Yes, Diluted 1:10
Flammability Requirements:
California Fire Code Technical Bulletin No. 117, Section E; UFAC Class I; BIFMA CS-191-53 Section 3; BIFMA Upholstery Section 4; MVSS 302; NFPA 260; Boston Fire Code (BFD IX-1); IMO A.652(16)8.2 & 8.3; ASTM E84 Adhered: Class I or A; NY/NJ Port Authority
![From the weeds to the wicked! (73 Chevelle) - Page 2 SYMBLA_1z](https://2img.net/h/www.onlinefabricstore.net/images/products/SYMBLA_1z.jpg)
Width: 54"
Thickness: 1.2 mm
Resilience SR: Yes
Is that a dash cap in that pic of your purchases?
No, that is the original dash. I already removed the top of it, but I cut it clean at the top edges with a dremel cut off wheel so I only need to build up from there back. The top was rotted away bad. I should have taken some pics of it's condition so everyone could have seen what I mean.
Thanks Tuff, being a married man, you just added to the list of ideas that will never happen in my garage. So I live vicariously through you.
![Beer](/users/1813/58/83/10/smiles/701728.gif)
Hey, I just noticed something. Your car has the same tires that I have on mine. Winston Winner GTs.
bigredlaguna wrote:Thanks Tuff, being a married man, you just added to the list of ideas that will never happen in my garage. So I live vicariously through you.![]()
Ha, well I guess I better do a good job then!
Yeah those things are all but gone. I pulled one clean off the rim trying to load this thing from its original resting place.driveit wrote:Hey, I just noticed something. Your car has the same tires that I have on mine. Winston Winner GTs.
I am in the process of figuring out which wheels and tires are going to replace those bad boys.
I really like the stance, wheel and tire size of Ray Evernham's 64 Belvedere
![From the weeds to the wicked! (73 Chevelle) - Page 2 Plymouth-belvedere-f_1600x0w](https://2img.net/h/pictures.topspeed.com/IMG/crop/201210/plymouth-belvedere-f_1600x0w.jpg)
you got some work ahead of you......holy smokes
good luck
good luck
1973montec- Donating Member
Yeah, I love the look of that car. I think it was featured in last months Hot Rod mag. It is on an actual nascar chassis that won a couple races I believe. I love the suspension under that car.
http://www.hotrod.com/featuredvehicles/hrdp_1304_thoroughbred_1964_plymouth_belvedere/viewall.html
Yes I have that issue! It's truly an amazing setup all the way around in every facet.
Other than the gauge choice, I can't think of hardly anything else I would have done differently if I had similar resources and money was no object and there are few rides out there that I can't pick apart in personal criticism, but this is one of the few I really can't think of anything.
I have always loved the old real steel NASCAR setups.
![From the weeds to the wicked! (73 Chevelle) - Page 2 IbwtSHq2rwctSk](https://2img.net/h/i3.minus.com/ibwtSHq2rwctSk.jpg)
I second that! That is the look I am going for as well. Excluding the rims.
Well its been a couple weeks since I have had time to post up progress due to many rodeo events, but I am getting back on track now so I will have some things coming real soon. I am experimenting with a couple ideas with the whole dash ordeal as well.
Interesting how everything sorta fits already, might reconsider the layout
![photo chevgauges_zps08431ad3.jpg](https://2img.net/h/i176.photobucket.com/albums/w184/WarCowboy/73%20Chevelle/chevgauges_zps08431ad3.jpg)
And one of me in PA on the circuit
![photo brm0-1_zpse406184b.jpg](https://2img.net/h/i176.photobucket.com/albums/w184/WarCowboy/brm0-1_zpse406184b.jpg)
I'm like'in the look of those gauges. Oh and how long did you hang on to that bull?
Love the Gauges but why not use a Round cluster Dash ?? would make fabbing a whole heck a lot easier, OH no I remember why because you using the Tablet Duh on my part ..
Yeah those gauges dont get the justice they deserve in pictures. And I didnt make but about 6 on him, but you cant cover em all! Anyhow yes, it doesnt matter which panel you start with for what im doing because of gauge size and like you said. The tablet deal. Also I will be removing the center bars from both sides and making a back plate for each. I will cover the remaining plastic with vinyl
As I promised, I am constantly trying new things when it comes to things I work on and as I have been tooling with this dash some I came to a great realization of some common products to get awesome results for repadding a dash cap. On these 3rd gen chevelles, I found that there is a lot of complex shaping under the original padding that posed a challenge for filling again. Without set dies and and injecting machine I believe I have found the ultimate solution for this issue. GREAT STUFF. Its cheap, can be found almost anywhere and when cured holds a great bond and stays flexible and on top of all that is easily shaved, cut and sanded into any shape with minimal effort.
I have actually have done this twice now, once to see if it was going to work, and then I stripped it back down just for you guys to do a video. Of coarse this is just a partial video that shows the initial application process and I will add more to show the entire process once I get more time.
gotta be the fastest cowboy I seen doing work LOL J/K very interested on final process for I have a dash to redo as well an who was the Music ?
Ha, yeah, and the song is "ten million slaves" by Otis Taylor
very cool tune I might say
Yeah I have a load of good music, hence the reason I have to have a killer sound system in my build. A great stereo can make a jalopy entertaining. I already have installed a set of FOCAL 6.5" components with external tweeters n crossovers powered by a helix 2chl amp. The mids and highs are awesome, just waiting to have a friend who is a stereo techy build a custom fiberglass box for the two 12's integrated into the trunck then ill be set.
build them into the Wheel wells I used to have them like that in the rear wells ....thru another member here and sounded awesome,
I am interested to see how the shaping goes ... I also, have two dashes that need to be redone .... I was saving up, to send one to Just Dashes ... but if you can pull yours off, I may reconsider.
They charge over a grand to do one now, so that would be quite a cost savings !
alleyball4- Donating Member
» Eastern Mass - Newbie, 1974 Laguna S3 454/4spd
» Dash assembly for the 1973-1977 Chevelle/Monte Carlo/El camino
» 1973 chevelle bumper vs 1974 chevelle bumper
Page 2 of 3
