need carrier info to upgrade wimpy 75laguna rearend
G3NUT
I'm compiling info to start my S3 summer project and need to know what vehicles to raid in the junkyard to replace the wimpy 2-series carrier with a 3-series so I can install 3.42 or 3.73 gears.I could not find carrier interchange info doing a search here.Thanx.
fishhead- G3GM Member
Re: need carrier info to upgrade wimpy 75laguna rearend
What gears are in it right now? Is your a posi or a one leg? Some 2 series carriers can be used with those gears you want. You can either put the spacer behind the gear like Mr. Gasket makes. Or you can get the gears that have the thick flange already build into the rear of the gear. Then it just bolts in.
Thanks! The gears are the original factory 2.56 open differential.I did not know there were thicker gears/built-in flange available for a series2 carrier.I REALLY LIKE that idea better than a spacer or robbing the guts out of the 73 mali.Where can I find these things?I'll have to check into it for sure.
Here's what the spacer looks like. http://www.summitracing.com/parts/mrg-908a/overview/
I'm not interested in a spacer but really curious about the thicker gears/built-in flange?
The rear isnt really wimpy at all. The 8.5 ten bolt is very strong and can be built as strong as a 12 bolt. The spacer works good, unless you are putting a lot of power to it -ALOT,it should be fine.
I installed a powertrax locker in my chevelle. It was a very easy install and works great but...it is kind of noisy. I already had Richmond 373 gears installed and the powertrax was a easy diy "posi" upgrade. It did cost $500.00 though.
It looks like my budget strategy is going to be a junkyard crawl to find a 3-series posi carrier to replace the existing carrier.I have a powertrax no-slip but its reserved for my 73.Anyone know of an online interchange chart for 73-77 8.5" 10-bolt GM rears? Thanks for everyones patience.
Haaaaate to beat this dead horse again but my question is this:My 75 Laguna rear gear ratio is 2.56(original factory gears)Does this mean my carrier is a Series2?
The way I understand it is that 2.56 and up will fit in same case and less than 2.56 will not fit. That is what I always heard. JBfishhead wrote:Haaaaate to beat this dead horse again but my question is this:My 75 Laguna rear gear ratio is 2.56(original factory gears)Does this mean my carrier is a Series2?
2.73 and numerically higher will fit a series 3 carrier.
70-81 camaro/ firebird uses a 8.5 carrier also
G3NUT- Donating Member
Yes, I think you are right. My memory is not what it used to be. JBG3NUT wrote:2.73 and numerically higher will fit a series 3 carrier.
I guess I'll be looking for a 3-series posi carrier then....dang it.
Try in a Caprice too. Wagon might have one. Im pretty sure they have a 8.5 too.
What models? Into the lower eighties?
Might be until the last ones in 96. Do some research maybe search part # on Rockauto.com try to cross part # from say your own car to one of them. I think some had the 7.5 rear -you dont want that. But I would bet the wagon has an 8.5. Try on here,search around http://www.impalassforum.com/
Monte SS is an 8.5 and usually has 3.73 stock. Buick GN usually have 3.42 stock. Both should be posi's. Dont rule out GM 1/2 ton trucks up to 99. Most of them have their option code sticker in the glove box. If you find the G80 code, thats a posi. Search the net and print out the list of other "G" codes which will tell you what gear ratio is in the rear. Will be something like GU4, GU5 or GT4 or GT5. Just looking for the "G"'s.
Huge help! I bookmarked your replies.Thanks much!
![study](https://2img.net/i/fa/i/smiles/icon_study.png)
