Heads.
+7
Jim_Rockford
DiscoMalibu
WyldeBill66
11 posters
Page 3 of 4
Page 3 of 4 • 1, 2, 3, 4
Re: Heads.
I wouldn't have wasted my time reinstalling a set of smog era thin casting heads, Time you had the machine work done, you could have gotten a good set of later model heads , or even a set of aftermarket vortecs.. and for the roloc pads, those are a no no for assembled engines , the grit will get everywhere. You might want to give it a little more time to clear out of the exhaust., Not sure if yours got a convertor or not, but it takes a good while for the water in the exhaust to dry out.
Jim_Rockford- G3GM Member
Re: Heads.
Unless you wanna buy me some heads and mail them to me from your own wallet, I'm using these. I'm a jobless college student. I'm not putting something on "just because". The only way this car will get new head(s) is if one is cracked and irreparable.
I wouldn't have "wasted my time" restoring a 77 Impala either, but I didn't say anything.
I've driven the car probably 50 miles, mostly on the highway...I'm sure if there was anything left in the exhaust, it's be gone by now.
Re: Heads.
I did..something..to it last night, and it seems to be getting better. Just a little smoke upon start up, then goes away.
However...I don't have any pressure on my upper radiator hose...
Re: Heads.
If the hose looks like it's being "sucked in", you may need to add coolant mix. If your radiator looks full- take the thermostat out and add some to the block through there- the block holds a lot of it.
Re: Heads.
Doesn't look like it's being sucked in...just no pressure when you squeeze it.
Re: Heads.
Did you check it when the system was hot or cooled down? Check the thermostat too it might be stuck- they're cheap to replace if you haven't already done it.
Re: Heads.
OK- "Poor coolant circulation" from my Haynes repair manual.....
1. Inoperative water pump:
To test- pinch the top hose closed with your hand while car is @ idle, then let loose- you should feel a "surge of water".
2. Restriction (clog) in cooling system
3. Fan drive belt defective or not properly adjusted
4. Thermostat "Sticking"
Re: Heads.
Number 2 could be plausible. It needs to be flushed...but I don't care to spend $80 to have it flushed out, if it has to all com apart again. I want to get the leaking/smoking to stop first.
I was talking to my dad about it tonight, and he remembers squeezing it the first afternoon we started it, and there being pressure. Now there isn't.
Thermostat is brand new...I doubt it's that...but hey, we all have bought bad brand new parts before...
Re: Heads.
Did you try burping the system? Runing it with the cap off to see if there is air in there? Is it over heating?
Re: Heads.
I hope I don't jinx myself saying this, BUT...
I think I have the leak fixed. Also, I now have pressure in my upper rad hose.
Re: Heads.
Took the car today to have the cooling system flushed and filled. While talking to one of the mechanics, he said it (the smoking upon start up) looks like valve guide seals. Does that sound about right?
Re: Heads.
yes the older cars did not have guides they were cst iron and they would go bad with the new gas no lead for lube so when you run it put in upper cyl, head lube until guides were replaced
davesr_7- G3GM Newbie
Re: Heads.
Well the good news is that if it is only the seals then the heads don't have to come off again. I found a video online that shows replacement to give you an idea of what's involved, you'll have to get some special tools but I don't think (even w/ tools) it'll be all that expensive.
http://www.partsgeek.com/ss/?i=1&ssq=valve+guide+seals+1974+monte+carlo&x=0&y=0
https://www.youtube.com/watch?v=ob_4-F-m1FI
Re: Heads.
I've done those seals a couple of times. No big deal. that video is right on. Use that type of valve spring compressor and not the leverage type that bolts to the valve stud. Easy job.
Question is, do you have BLUE smoke or WHITE smoke. In the pic it looks like its white. White is antifreeze, blue would be oil. If you have blue then your talking rings or the seals mentioned above. If the smoke is white I'd be looking elsewhere. A leak down test might be in order.
Re: Heads.
Whats really weird is that it only smokes sometimes.
Earlier today, let it sit 5 minutes or so, quite smokey. Now, it has been sitting maybe 3 hours or so...ZERO smoke AT ALL.
I'm just so stumped anymore, and tired of these "guessing games" that keep costing me money that I don't have.
![scratch](https://2img.net/i/fa/i/smiles/icon_scratch.png)
Re: Heads.
Man that's crazy...
I get smoke in the am w/ my daily driver & it consumes about a half quart of oil every 1,500 miles or so...Is the car consuming any oil at all?
Re: Heads.
It doesn't seem to. But, I don't drive it often enough to notice if its burning/using oil. I may drive it 1500 miles a year, and still change the oil 2-3 times.
Re: Heads.
You know, I kinda had a problem like this too. Its still kinda there too. It smokes when I first start it when its cold (valve seals) but then continues to smoke but not all the time. Maybe something to do with the outside temperature. On my 73.
Re: Heads.
If there is nothing in your oil (water) or oil in your water and its not overheating just drive it the smoke might clear up or something else might come to light that is the problem.
Re: Heads.
when chking guides chk foor play in guide a bad guide will cause big problems
Re: Heads.
Now I have a dented rim...LOL. I hit a curb, going over a narrow bridge yesterday. Dented the rim, dented the trim ring, and knocked the battery out of the hold-down. "If I didn't learn to laugh at myself, I'd be dead right now."
Page 3 of 4
