74Malibu383 Build
+42
Iguy
builtnotbought
ratnfested
testpilot61
black eyes
77ElClassic
switchbiker
2fat2fly
Oldschool454
G3NUT
Fishgrinder
carcass
Malicruiser
Dubie
Trbulnc
72ragtop
Famstyle
Cdub74
46 posters
Page 2 of 12
Page 2 of 12 • 1, 2, 3, ... 10, 11, 12
Re: 74Malibu383 Build
Looking good can't wait to see that thing on the street
McCauley5983- G3GM Enthusiast
Sorry for the crappy photos... It doesn't do the paint justice. The firewall and EVERY other part was wet-sanded after the primer coat was shot.
![74Malibu383 Build - Page 2 2012-019](https://i.servimg.com/u/f49/13/69/09/13/2012-019.jpg)
Core Support
![74Malibu383 Build - Page 2 2012-020](https://i.servimg.com/u/f49/13/69/09/13/2012-020.jpg)
Brake Booster - Probably have 3 hours in sanding, priming, wetsanding, and painting this damn thing.
![74Malibu383 Build - Page 2 2012-021](https://i.servimg.com/u/f49/13/69/09/13/2012-021.jpg)
Core Support
74Malibu383- Donating Member
Looks great. What brand did you end up using for the paint? Looks like semi-gloss?
(BTW- don't forget about the little gasket behind the booster.)
It's Hot Rod Flatz Black from TPC Global.
http://www.tcpglobal.com/kustomshop/ksflatz.aspx?gclid=CPv4ncP-qq8CFWcZQgod_wohWQ
Already got the gasket! Thanks!
Built 383 with all Forged Internals. Redline 7500. Max Boost 16PSI.
Built 4L80E with billet input/intermediate shafts - Should be good to 1000hp.
![74Malibu383 Build - Page 2 2012-022](https://i.servimg.com/u/f49/13/69/09/13/2012-022.jpg)
![74Malibu383 Build - Page 2 2012-023](https://i.servimg.com/u/f49/13/69/09/13/2012-023.jpg)
![74Malibu383 Build - Page 2 2012-024](https://i.servimg.com/u/f49/13/69/09/13/2012-024.jpg)
![74Malibu383 Build - Page 2 2012-025](https://i.servimg.com/u/f49/13/69/09/13/2012-025.jpg)
JiMi_DRiX wrote:Hot damn.... thats looks goooooooood!!
Agreed!
Very, very nice !
The 4L80E will handle a LOT of power, so not likely any problem there !
Global West Upper and Lower Control Arms with QA-1 adjustable coil-overs
Upper: CTA-37A
1. Increased Caster with 5-1/2 degrees of positive caster built into the control arm, straight line stability and corner entry is dramatically improved.
2. Camber curve is improved for high speed maneuvering.
3. Special bump stop mounted on the cross brace provides full drop protection for the ball joints.
Lower: CTA-37H
1. Doubling plates are used in the loaded areas where the shock bolts to the arm.
2. Cross tubes support the loaded shock mounting area and outside main tubes.
3. The sway bar mounting plate adds support to the ball joint area.
4. Straps are used around the bushing housings strengthening the housing to the tube.
![74Malibu383 Build - Page 2 2012-027](https://i.servimg.com/u/f49/13/69/09/13/2012-027.jpg)
![74Malibu383 Build - Page 2 2012-028](https://i.servimg.com/u/f49/13/69/09/13/2012-028.jpg)
Upper: CTA-37A
Lower: CTA-37H
Where the heck is the drool emot on here????
:-P........
:-P........
77mali wrote:Where the heck is the drool emot on here????
:-P........
OH BUT WE DO and then some LOL
74Malibu383 wrote:Global West Upper and Lower Control Arms with QA-1 adjustable coil-overs
Upper: CTA-37A
Lower: CTA-37H
![:<P](/users/1813/58/83/10/smiles/2615402659.jpg)
77mali wrote:LOL- you just added that!!
Who me I am Innocent LMAO
Been working on the car EVERY night. Just haven't had time to post progress.
![74Malibu383 Build - Page 2 2012-029](https://i.servimg.com/u/f49/13/69/09/13/2012-029.jpg)
Bent new brake lines, and rewired the entire engine compartment. Loomed everything in braided loom.
![74Malibu383 Build - Page 2 2012-030](https://i.servimg.com/u/f49/13/69/09/13/2012-030.jpg)
![74Malibu383 Build - Page 2 2012-031](https://i.servimg.com/u/f49/13/69/09/13/2012-031.jpg)
![74Malibu383 Build - Page 2 2012-032](https://i.servimg.com/u/f49/13/69/09/13/2012-032.jpg)
![74Malibu383 Build - Page 2 2012-033](https://i.servimg.com/u/f49/13/69/09/13/2012-033.jpg)
![74Malibu383 Build - Page 2 2012-034](https://i.servimg.com/u/f49/13/69/09/13/2012-034.jpg)
its been there for a couple of months already
Real nice job...hard work pays off for sure.
Were did you get the wire looms from? They look great.
Superb workmanship on that project. Thanks for the pics !!
Man... it's been a long time since I've been on here. Got the car done back in June and took it on Power Tour. Been swamped at work since. Here are a few more photos...
In order to install the 4L80E, I had to move the crossmember back. Unfortunately, the stock one hits the floor before it can move back far enough to bolt up correctly. So... out it went, and I made this one. 2"x4" square tubing with 1/4" thick round tubing for the exhaust passages. I cut off the ends of my stock crossmember to save some time...
![74Malibu383 Build - Page 2 2012-010](https://i.servimg.com/u/f39/13/69/09/13/2012-010.jpg)
![74Malibu383 Build - Page 2 2012-011](https://i.servimg.com/u/f39/13/69/09/13/2012-011.jpg)
Once installed, my buddy and I made up the new exhaust by cutting up some 3" mandrel U bends. I cut off the 3 bolt collectors on the headers and went with band clamps. The photo shows the bolts on the bottom, but that was just for mock up. Final install puts them above the exhaust, so no more worrying about scraping speed bumps. Also decided to weld three bolt collectors between the mufflers and front exhaust section to allow easy removal of the main section. Took a while, but came out nice. Still need to take it all back out and sand/paint. Just didn't have enough time to do so before Power Tour.
Exhaust - Went with Spintech's this time. Love them!
![74Malibu383 Build - Page 2 2012-014](https://i.servimg.com/u/f39/13/69/09/13/2012-014.jpg)
![74Malibu383 Build - Page 2 2012-012](https://i.servimg.com/u/f39/13/69/09/13/2012-012.jpg)
![74Malibu383 Build - Page 2 2012-013](https://i.servimg.com/u/f39/13/69/09/13/2012-013.jpg)
Used a 3" hole saw on his mill to notch the H-Pipe:
![74Malibu383 Build - Page 2 2012-017](https://i.servimg.com/u/f39/13/69/09/13/2012-017.jpg)
![74Malibu383 Build - Page 2 2012-015](https://i.servimg.com/u/f39/13/69/09/13/2012-015.jpg)
![74Malibu383 Build - Page 2 2012-016](https://i.servimg.com/u/f39/13/69/09/13/2012-016.jpg)
Looks awesome man.
What purpose does the bracket serve around the drive-shaft by the trans- is that a "just in case" provision?
Looks like a low profile driveshaft safety loop. Good thing to have. I run one. I dropped my shaft twice.
Yup - Driveshaft safety loop. I originally put it in 6 years ago with the stock driveshaft and everything was fine. Unfortunately, when I stepped up to the 3.5" shaft it started rubbing. It's out of the car now, and I'm making a new one. Going to try and make one that looks a little better.
Cargasm!!!!74Malibu383 wrote:Man... it's been a long time since I've been on here. Got the car done back in June and took it on Power Tour. Been swamped at work since. Here are a few more photos...
Malicruiser- G3GM Member
I see its an older thread but may i ask what brand and part number your headers are and if you are happy with them?
carcass- Donating Member
Page 2 of 12
