MSD boxes/any ignition box mounting
+8
2fat2fly
Jedediah
12 posters
Where do you guys have them mounted ? I have mine on the passenger side wheel well and it looks sloppy I was thinking of just moving it to the other side (wires would be shorter) and it would not look as sloppy. Any ideas ?
Re: MSD boxes/any ignition box mounting
Am I the only that uses an Ignition box ?
None here Ant, sorry. HEI only.
I have an MSD box, but it is also on the pass wheelwell. Pics and compare?
How do you have the harness routed? Mine goes around the heater box (AC box) then across the firewall to the dist. I have the power for the box at the big terminal on the starter and the ground direct to the battery.The harness looks messy I want to put the box on the other side and send it behind the booster. I cant really see where else I could put it.
I have heard of people mounting em under the dash, so they are out of sight. I put the last one I installed on the passenger fender and routed it similar to how you describe yours. I just made sure it was secured and in that plastic wrap.
Jedediah- G3GM Member
Mine is under the passenger cowl vent, and the coil is just poking its head out next to the msd dist., all the wiring is thru the firewall.ant7377 wrote:Where do you guys have them mounted ? I have mine on the passenger side wheel well and it looks sloppy I was thinking of just moving it to the other side (wires would be shorter) and it would not look as sloppy. Any ideas ?
Plenty of room to do !
Never have had any issues with wet weather, (rain or car washing)
![happy bowtie](/users/1813/58/83/10/smiles/78730.gif)
2fat2fly- Donating Member
I made a panel that fits where the glove box would be. I have a 6AL, Retard Control, BTM, and HVC coil mounted on this panel. All the wiring is out of sight, out of mind. I had to remove the factory glove box lining, but there's still room in there to make another one, it just wouldn't be as deep.
74Malibu383- Donating Member
I made a custom bracket that holds it horizontal above the heater box. The adjustment dials are facing forward and easily accessible. (Factory non a/c car)
dynchel wrote:I made a custom bracket that holds it horizontal above the heater box. The adjustment dials are facing forward and easily accessible. (Factory non a/c car)
Dynchel, can u post a pic? My car is non a/c as well. I have my accel super coil mounted about the blower/heater box right now. I'm figuring that I'd mount the 6al in that spot and a smaller coil right next to it on the firewall. My new manifold doesnt have the mounts for a coil to put put in the stock location.
I don't. Have any pictures, and the car is stored away for the winter. I pretty much made a 90 degree bracket and centered above the heater box. I am using a accel hei super coil that mounts on top of the cap. I have a power "stud" on the firewall near the wiper motor i use for power. This makes for a clean install with minimal wiring showing. When i get the car out in the spring i plan to take several pics to post. (Since everyone keeps asking.)
I'll take a better picture later, but my MSD box and ignition control are on the passenger side wheel well. I like how they look, they fit nicely, under the AC hose, and, there is room under them to neatly tuck the wires.
![MSD boxes/any ignition box mounting 252688_2118322083505_2977960_n](https://2img.net/h/sphotos-a.xx.fbcdn.net/hphotos-ash4/252688_2118322083505_2977960_n.jpg)
JiMi_DRiX- G3GM Enthusiast
Great looking engine compartment Jimi !!
You know how hard it is to find good unbroken, unaltered, PLASTIC fenderwell in Az? I couldn't drill 'em. ... That's just me though, Ha Ha!
![Razz](https://2img.net/i/fa/i/smiles/icon_razz.gif)
Pontichev327- G3GM Enthusiast
By the way, that is a great lookin' engine compartment!
Thanks guys! I figured the MSD boxes aren't ever going anywhere, so drilling them was ok. I put two black plastic panel clips in the holes where my cruise control was. Today I worked on the MSD plug wires.
![MSD boxes/any ignition box mounting 20121223_184119](https://2img.net/h/i30.photobucket.com/albums/c347/JiMi_DriX/20121223_184119.jpg)
![MSD boxes/any ignition box mounting 20121223_135751](https://2img.net/h/i30.photobucket.com/albums/c347/JiMi_DriX/20121223_135751.jpg)
I have my box and coil mounted under the dash almost directly behind the dizzy. When I install these into my chevelle I'll mount inside the glove box once I remove the liner.
Bruisr- G3GM Member
https://2img.net/h/i1337.photobucket.com/albums/o674/dynchel/photobucket-39856-1361895393537_zpsbfe8166f.jpgJoe73 wrote:dynchel wrote:I made a custom bracket that holds it horizontal above the heater box. The adjustment dials are facing forward and easily accessible. (Factory non a/c car)
I finally got aroung to posting this pic.
![Drinking Party](/users/1813/58/83/10/smiles/545593.gif)
Looks good are the louvers functional?
I always vote no to hood pins.
Louvers are fake just like they were on the original application.
I just realized i posted in the wrong spot for the lovers/hood pins
MSD box looks good too fells.
i noticed that but figured you were responding to two different threads with one response.77mali wrote:![]()
