700r4 help
700r4 help
hey guys, have been looking for a good 700r4 core for a long time and havent been able to find one, finally found one online, getting ready to go look at it pretty soon. I called the guy, can tell he doesnt know jack about cars, I wanted to know what year the trans was because im only interested in 87-92, the guy said he got the trans already pulled and doesnt know what kind of car it came out of, also he says there are no numbers on it, so what I asking for help on is it anyone here knows how to ID these transmissions without serial numbers.
Re: 700r4 help
http://www.thirdgen.org/techboard/transmissions-drivetrain/48475-identify-early-vs-late.html
Re: 700r4 help
red, this is outstanding info, thank you.
Re: 700r4 help
UPDATE 4/11/11
Built With:
87 "K-Code" 700r4 core
Monster Transmissions "Mega Monster" Rebuild Kit
AC Delco Five Pinion Planetaries
TCI Constant Pressure Valve Body
Carb TV Kickdown Bracket
B&M TV Cable
B&M Lock-Up Converter Control
Corvette 2200 Stall Converter W/ upgraded Thrust Washer (4130 Steel)
Total Invested: $2025.00 (not including paying to have the drive shaft shortened, I haven't done that yet)
Built With:
B&M TV Cable
Last edited by TWBouska AKA Wooderson on Mon Apr 11, 2011 6:48 pm; edited 1 time in total
Re: 700r4 help
Sounds like it will survive a heavy foot!! What rear end ratio ?
Re: 700r4 help
right now just the stock gears (not sure on which ones they are for sure) but after the trans itll be getting 3.73's and a posi.
Re: 700r4 help
man as much as having an overdrive is nice I sure dont like TV cable transmissions. Hope it works out well for ya.
![700r4 help SIG2](https://2img.net/h/i23.photobucket.com/albums/b357/greenchevelless/My%20Chevelle/SIG2.jpg)
BlackChevelleSS- Management
Re: 700r4 help
Somebody stickied a link I posted about TV setup in the engine & driveline section. Check it out if you haven't already.
Re: 700r4 help
i got the b and m stuff, we used it in the 70 chevelle and the thing works great,when i get it all together ill give you guys a complete parts list in case you wanna try it, i NEED that overdrive with the way gas has gone up...i might leave the stock rear end gears in it too since its a daily.
Re: 700r4 help
with a 700 first gear is so short that you dont need much gear to get off the line. 3.42 or 3.55 is where id stay at
Re: 700r4 help
i thought about 3.42's, i was going to run them if i ended up putting in the 454, but with gas going up like it is i kinda put that off, but i still might just go 3.42s anyway
Re: 700r4 help
Unless you do a lot of drag racing, you dont need that low a gear. For a street car with a big block torquy engine and an overdrive trans a 2.73 will work fine. Sure, a 3.08 would be even better. Its these small block cars that need these real low gears because they are not as torquy. JB
Re: 700r4 help
yeah, i was hoping to use the big block but for a daily in a car that gets a lot of miles i think its best i stick with an sbc...i got a 010 casting 350 4 bolt motor im rebuilding so ill probablly stick with that. The set up im running has pretty good low end torque as it is, so it might be ok, rearend needs rebuilt anyways though, axles at the minimum.
Re: 700r4 help
That old saying; "you can't have your cake and eat it too" ,or if ya wanna play ya gotta pay!
Our fun is costing way too much these days...
Re: 700r4 help
When it comes to good gas milage, the way you drive has as much to do with it as to what engine you have in it. When I first got my 540 put in I drove it down to Elizabethtown and back on I-65 to break the engine in and got about twice the gas milage I expected to because I took it easy, I only got up to 70 once or twice. JB
Re: 700r4 help
another good point j2b...i baby my car...its so expensive to live out here and i only make about 40k a year that i dont beat on my car at all because i cant afford to fix it for the same amount it cost me the first time around...im gonna be taking 4 of my A.S.E's (auto certifications) in May so that should qualify me for about a $10 per flat rate hour raise so thankfully that should help.
Re: 700r4 help
Good luck with your certifications. The industry needs good techs.
Re: 700r4 help
thanks Pila...I will have my work cut out for me.
Re: 700r4 help
I just put a 700R4 in mine about 2 weeks ago. Excellent hwy mileage now... pretty closely doubled, around town, not so much. Do love that OD though. I used one of the older R4's (86) and he upgraded the pumps and I think he said the clutch pack assembly. I brought in a Transgo kit, and I tell you that thing rocks.
Pdawgie- G3GM Member
Re: 700r4 help
yeah im pretty excited for it, most of my driving is highway, my girlfriends dad has one in his car with a similar 350 to mine in it and hes getting about 24 mpg's highway, so im hoping for at least 22 since my motor is a little more cammed up than his.
Re: 700r4 help
I've used a few Transgo shift kits, mostly in TH350s. They seem better than others I've tried.
Re: 700r4 help
never heard of them, but i was really happy with the customer service at Monster, we'll see how the product turns out here in a week or two when i get the tranny installed.
Re: 700r4 help
I did a TH400 for my El Camino, and used a Transgo in that one too.
