i just got a power window setup....
G3GM :: G3 Tech :: Electrical
i need to know how to hook them up to the battery i am going to put them in the passengers door tomorrow
Re: i just got a power window setup....
77malibu77 wrote:i need to know how to hook them up to the battery i am going to put them in the passengers door tomorrow
you first need a relay,the relay gets its power from the IGN terminal on the fuse block and than the wires go to the switches.
ok thx
and back onto the power window subject i have a power window motor i think its out of a 80 something camaro (maybe 87), and i am trying to make it work with my doors but i have to drill in new holes in the door
i only want to make new holes once,so how can i do it any tips
Drill slowly and use grommets. Not too sure what other tips you're looking for.
74Malibu383- Donating Member
idk well the arms look a little bit smaller than the manual window ones, but i guess ill go try and get it
On my 70 someone cut the original PW wiring so I made my own. I didnt hook it to the ignition on, instead its hooked to the power side on the fuse block (always on, I can then roll my windows up or down without a key on) then I used a auto circut breaker so when the motor sees a big load (all the way up or down) the circut breaker cuts power to prevent the motor from burning up.
![i just got a power window setup.... SIG2](https://2img.net/h/i23.photobucket.com/albums/b357/greenchevelless/My%20Chevelle/SIG2.jpg)
BlackChevelleSS- Management
BlackChevelleSS wrote:On my 70 someone cut the original PW wiring so I made my own. I didnt hook it to the ignition on, instead its hooked to the power side on the fuse block (always on, I can then roll my windows up or down without a key on) then I used a auto circut breaker so when the motor sees a big load (all the way up or down) the circut breaker cuts power to prevent the motor from burning up.
thanks thats definately an idea!
![What a Face](https://2img.net/i/fa/i/smiles/fresse.png)
