Its Road Captains Fault Blame him
So Thanks To Roadcaptain I am doing this ....... 305 Build going to shoot for 320hp on this Build and I would be very happy with that...
Longtube headers (got)
600cfm carb (got)
rpm style mani (got)
2.5" exhaust (got)
305ho Heads (working on deal)
I have almost everything I would Need besides gasket Kit for all the Change ( now I know why I save Parts LOL)
600cfm carb (got)
2.5" exhaust (got)
Re: Its Road Captains Fault Blame him
Did you get the 416 casting heads too?
How will you know? Going to dyno when your done?
Tom77- Donating Member
Tom77 wrote:How will you know? Going to dyno when your done?
Excellent question.
bracketchev1221 wrote:Did you get the 416 casting heads too?
Yes sir #416 heads that are Bolt on ready
Roadcaptain S3 wrote:Tom77 wrote:How will you know? Going to dyno when your done?
Excellent question.
If its in the Budget yes we have one that is real close to me
I have a question Limey. I know that 2 1/2" exhaust is what everybody seems to run on their cars, but for the little 305 is it too big? Maybe 2 1/4" would be better? Just wondering is all.
not sure I have the 2.5" already BUT sure don't want to use the 2" pipes that are on it Now
Yeah 2" pipes usually have more of a kackel to them. lol
Are you replacing the cam?
The camshaft selection will be a key in getting all the other goodies to make some power !
bracketchev1221 wrote:Are you replacing the cam?
pila wrote:The camshaft selection will be a key in getting all the other goodies to make some power !![]()
#416 Heads are a done deal Thanks To Shirt Buisness And this is The Cam
http://www.lunatipower.com/Product.aspx?id=2325
Voodoo Hydraulic Flat Tappet Cam & Lifter Kit - Chevrolet Small Block 268/276
Hydraulic. The most awesome 268 cam ever produced! Out-powers all others! This High Performance street cam likes 2400 RPM stall, 700 cfm carb, dual plane intake and headers. Makes un-equaled power to 6200 RPM with proper valve springs. If you're looking for a Very Strong cam with great street manners then this cam is it.
Advertised Duration (Int/Exh): 268/276
Duration @ .050 (Int/Exh): 227/233
Gross Valve Lift (Int/Exh): .489/.504
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1800-6200
Includes: Cam & Lifters
I assume you have enough compression ratio for that cam ? Duration at .050 looks good....
compression will be 9.4 - 1 With new Heads and Cometic Gasket
That's a stout cam for a little 305 indeed. I assume you'll be using something other than a stock converter Limey? I ran one of these when I had my 305 in my S10. It worked out really nice behind the little motor.
http://www.autopartswarehouse.com/shop_parts/torque_converter/chevy/vega.html
http://www.partsgeek.com/m3bp5wv-chevrolet-vega-auto-trans-torque-converter.html?utm_source=bing&utm_medium=ff&utm_content=MP&utm_campaign=PartsGeek+Bing&gb=pp&utm_term=1971-1977+chevrolet+vega+auto+trans+torque+converter+dacco+71-77+chevrolet+auto+trans+torque+converter&ad=11620898036
Yea Searching for 2200 to 2400 Thats recommended for the Cam, stock is around 1600 to 1800 Depending who you ask
The Vega converter stalls about 2400 or so. It was a cheap trick used back in the 70's by street racers.
Will that Fit my 350th tHough ??
Yep. The Vega trannys were TH350 as well. Slip right in. You just have to make sure your flywheel is a dual bolt pattern where the converter bolts up. But I'm sure most all of the flywheels had that feature. I'd bet you have the smaller, 153 tooth flywheel. That's what I had and not sure if I ever saw a 168 tooth flywheel on a 305.
Message me On Face book em Dano Please LOL
Limey, I don't think you'l be happy with that cam. Don't forget the smaller the motor the "bigger" the cam will act. I'm not a fan of the 110LSA, kills vacuum, that's me though. You'll also need a minimum of a 3.5 gear out back for that cam. Â By comparison, I have a 228/238@ .050, .540 lift, 114 lsa in my 454. I'm very happy with it, 12 1/2~13 inches of vacuum, nice idle, doesn't load up when pulled down in gear, supports the A/C also. Nice aggresive sounding idle, pulls strong to 5700. I had a comp extreme energy in it prior to that, ran it for 2 years, just wasn't happy. stinky idle, noisey, etc. Probably could have got the idle better with a holley HP series carb but didn't want to go that route.
73ss- G3GM Enthusiast
Most I would go with is
https://m.summitracing.com/parts/lun-10120702
Here is the post from the other 305 build posting on cams
The XE262H-10 comp cam is good, the XE 268 is going to be pushing it in a little engine. Lunati has the 10120701 cam and again, the 10120702 is a little bigger, not as bad as the comp 268 so it may be a possibility
bracketchev1221 wrote:Most I would go with is
X2.
The point I was wanting to make in the previous post is, The Lunati cam you listed is very similar to what I am running. that's how it behaves in a motor with 150 more cubes and a verified 10.07: 1 CR. Take a look at a factory L-82 vette cam for the 305, might be a good choice. Crane offers them.
