Rear end measurement..
wbaker01
Does anyone have the rear end measurement handy? axle flange to axle flange?
Thanks,
Bill
Thanks,
Bill
wbaker01- G3GM Member
Re: Rear end measurement..
Hard to get axle flange to axle flange with the ring and pinion installed. But this is what I have.
73 chevelle rear I have for sale is 54" inside edge to inside edge of the brake backing plate. I put the tape on the outermost circumference of the backing plate right next to the drum. I tried to get a measurement from the back of the mounting plate to the back of the mounting plate and best I can get is 55 1/2" on this axle.
The next 2 measurements were measured at the same spot on the outermost edge of the backing plate.
My original 1973 3.42 rear is 54 1/4" inside backing plate to inside backing plate.
My 77 monte rear in my car comes in at 54 1/2" inside backing plate to inside backing plate.
Hope this helps. If you need other measurements just post up.
I have a 77 Malibu one as well out of Car if need a Measurement
For the sake of not starting a new thread I'll just ask here:
Does anyone have the length of the rear sway bar?
SonOfTheGrim- G3GM Member
I'll measure the extra sway bar I have SonofTheGrim later and let you know what it is.
Thanks much. I'm trying to figure out how I can adapt a new camaro or gto rear bar to my car.
I think Bill wanted the measurement between the axle flanges behind the brake drums, over-all width etc..
This thread was started last year sometime. I was trying not to start a new thread.
it's actually better to start a new thread with a title that is well-detailed for the exact subject matter. That way if someone else needs to search for the same thing you were looking for a few years from now, it will show up a little faster maybe.
clanceman427- G3GM Enthusiast
» Need measurement between frame rails where rear crossmember is at
» rear end ?
» 73-77 A vs 77-96 B suspension swaps
» rear end ?
Today at 6:40 pm by zucchi
Yesterday at 12:38 am by Limey SE
Thu Sep 05, 2024 8:38 am by Limey SE
Tue Sep 03, 2024 9:08 pm by Limey SE
Fri Aug 30, 2024 5:50 pm by Limey SE
Wed Aug 28, 2024 8:51 am by zucchi
Sun Aug 25, 2024 8:05 pm by Keith Seymore
Tue Aug 20, 2024 8:54 pm by Limey SE
Mon Aug 19, 2024 11:08 pm by 76Chevelle2Tone
Sun Aug 18, 2024 3:02 pm by Limey SE
