Hood hinge lubing
Hood hinge lubing
Anyone have any good tricks to lubing the hood hinges? And what are you using? White lithium grease looks like a mess on all those pivot points especially with a painted and detailed hinge.
Re: Hood hinge lubing
I usually just use wd40 with the straw attachment.
White lithium with a straw & I clean the excess with a rag. What did you end up doing for your bad hinge in your other post?
73ss- G3GM Enthusiast
I picked up a hinge off eBay. Guy said.it was tight with no play and.it was when I got it. So I blasted and.painted it. Put the.low.tension spring on it and.I was.good.to go. Thanks for the straw tip.
» Tailgate right plastic hinge cap
» 73-77 El Camino / Chevelle LH upper door hinge
» 1976 Monte Door Hinge Bolt Plate
