How I did it: Widen Steel Wheels at home
G3GM :: G3 Tech :: Wheel / Tire fitments
My Dad and I have widened a number of steel wheels at home, most notably converting 15x7 truck sport full face wheels (Motorwheel) to 15x8; and converting 15x8 Corvette rally wheels to 15x10 or 15x12 configurations.
We widen the wheels by preserving the front half (thereby keeping the dimensional integrity between the wheel spider and the front face of the rim) and by cutting the back portion off the wheel.
A new back portion, from a different wheel and with an additional 2", would then be fixtured to the front face/spider, using this spacer as a checking fixture, for a 10" wheel. To create a 12" wheel the front face would be cut and replaced after that rear portion was secured.
This is the spacer, used as a fixture for controlling the overall width, made from a piece of black pipe.
The length of the spacer corresponds to the final wheel width. These are placed in three or four locations around the wheel and are secured with small screws in the end.
A small plate was affixed in four locations, allowing for minute adjustments of the donor portion. Once the radial and lateral runout are within spec then the two halves can be welded together.
Here is a finished sample, a 10" Corvette rally with the front spacing preserved and the 2" added to the rear.
Keith Seymore- G3GM Member
Re: How I did it: Widen Steel Wheels at home
That's pretty impressive Keith. Why didn't you just buy some lighter aluminum wheels? I had 15/8 corvette rally's and those suckers were heavy. It seems your car is mostly a racer I would think you would want less unsprung weight.
Last edited by dynchel on Tue May 12, 2015 10:59 pm; edited 1 time in total (Reason for editing : correction)
I was going to ask if you ran into balancing issues, but then I saw the 4 large balance weights on the inside rim, so I guess that answers my question.
thatfnthing wrote:I was going to ask if you ran into balancing issues, but then I saw the 4 large balance weights on the inside rim, so I guess that answers my question.
That's from the tire. It's not uncommon for me to have that many weights on a production wheel with the slicks or M/T tires mounted (note that they are all on the backside, rather than being split so that you could see them on the front).
We do spin the wheels alone before putting the tire on but no weight adjustment has ever been required.
K
dynchel wrote:That's pretty impressive Keith. Why didn't you just buy some lighter aluminum wheels? I had 15/8 corvette rally's and those suckers were heavy. It seems your car is mostly a racer I would think you would want less unsprung weight.
Thank you - yes - I could shave a few pounds and a couple tenths with lighter wheels and smaller tires but the rallys have sort of become a "signature piece" now. A lot of people comment on them.
It sort of adds to the mystique of the "big, heavy" Chevelle running high 9's/low 10's.
K
Very cool Info Keith thanks for sharing this Information !!
What is the backspacing on the 10" wheel?
BBMALIBU- G3GM Member
BBMALIBU wrote:What is the backspacing on the 10" wheel?
Stock + 2 (probably 6").
It moves the tire/wheel assembly inboard without having to narrow the axle.
K
Very nice pice in the chevy mag were did you get your hood?
black eyes- G3GM Member
black eyes wrote:Very nice pice in the chevy mag were did you get your hood?
US Body Source, in Florida.
I have a bolt on flat hood (40 lbs) and the lift off cowl (20 lbs); stock steel hood is 80 lbs.
The quality and fit were not very good but they are one of the few places to offer parts for our cars (at least, back then).
K
This would be easier, I think. I did it like this many years ago.
http://www.speedwaymotors.com/Shop/Bart-Wheel-Shells/20.html
77cruiser- G3GM Member
77cruiser wrote:This would be easier, I think. I did it like this many years ago.
Maybe, except:
a) With my way the wheel "spider" portion stays attached to the front bead of the rim, ensuring dimensional integrity and giving me a spot to fixture the back side.
(Counterpoint - after cutting the spider out a person would still be able to install the Bart wheel shell and check for runout, both lateral and radial)
b) Mine was "free" - since I already had all the wheels.
(Counterpoint - yeah, but Seymore - you wasted a couple Corvette rally wheels to do it your way)
I think it might be incrementally easier to cut the back off an existing wheel than to cut the spider out of a wheel. Maybe not.
K
Also -
We developed the technique in order to widen these "full face" Motorwheels, as shown on the pickup:
(the argent version of the 454SS wheel).
That's probably what pre-disposed us to go this way on the Corvette wheels.
We wouldn't have been able to use the Bart wheel shells on those.
K
K
» Are the new '120mm' 5 bolt wheels equal to 4.75" 5 bolt older style wheels?
» Stainless steel!!! >:(
» stainless steel pipes
Yesterday at 12:14 pm by g3chevy / Mr Pontiac
Yesterday at 12:11 pm by g3chevy / Mr Pontiac
» Street Machine Nationals
Mon Jul 15, 2024 7:28 pm by Nutnhoney29
» 73-77 Chevelle/EC/Sprint RH Lap Duct Assembly BLUE
Mon Jul 15, 2024 3:09 pm by 73ss
» '74 Laguna S-3 project, central California $2500
Sat Jul 13, 2024 9:31 pm by FumiyoG3
» NOS Olds Cruise Control kit 78-80
Sat Jul 13, 2024 3:38 pm by Joe's Olds
» 1976 Chevelle front bumper guards NOS
Fri Jul 12, 2024 8:25 pm by Limey SE
