+41
zucchi
76 Malibu
76Chevelle2Tone
S3TPI
Sinister
Flywheel
1975 S3
Jeff-45
1cheapshot
JF74chevelle
Tom Kochevar
dine73ss
alowerlevel
RossK73
marks454ss
BK-75
45 posters
Page 17 of 17 Previous  1 ... 10 ... 15, 16, 17
1973 Chevelle SS, 350, 4spd. build - Page 17 Empty Re: 1973 Chevelle SS, 350, 4spd. build
Post by Joe73 Thu Mar 21, 2024 7:03 pm
Thanks for the pic. I do have some holes up there which I plan on using for mounting a bracket of some sort.
Street Cred : 83
Post by zucchi Thu Mar 21, 2024 7:13 pm
Joe73 wrote:I checked above the glove box for any studs.
It's been about 30-years since I last had the dash pad out of the car (I may also be getting senile 1973 Chevelle SS, 350, 4spd. build - Page 17 1f60b ) but I seem to recall that on the back/inside of the dash pad itself, there were studs for mounting the amp similar to the studs used to mount the AC vents.
zucchi
zucchi
Street Cred : 4
Post by g3chevy / Mr Pontiac Thu Mar 21, 2024 8:33 pm
"Here is what Zucchi is referring to. I removed this from my car many years ago when I did a dash swap. I do not remember where it was mounted behind there. I included a pic of the mounting holes, You would still need to fab a bracket to make use of them. My car must have had the optional stereo. It still has the dual speaker mount for the dash that was shown recently on another post, and it still has the factory wiring for the rear 6X9's in the trunk to this day. I still have the speaker covers for the underside of the speakers in the trunk. The factory radio was long gone when I got the car.
Does anyone have a pic of what the correct factory radio looks like, for a 73? I have several Delco radios but would like to see a pic of the correct one."
Here's a 73 dash I have with the factory original radio. Let me know if you like me to take a close up pic.
1973 Chevelle SS, 350, 4spd. build - Page 17 20191110
Street Cred : 34
Post by Joe73 Fri Mar 22, 2024 11:16 am
I just checked behind the dashpad itself.  Yes, there are two standoffs about 2" tall.  Something can easily be threaded into them.  I might give it a shot.  Thanks again for the idea.
Here is a pic of my original 73 am radio.  Probably not what your looking for since you have the factory dual 6x9s out back.  Mine was just a dash speaker from what I can tell.  Pic doesnt do the radio justice.
1973 Chevelle SS, 350, 4spd. build - Page 17 Radio10
Street Cred : 83
Post by zucchi Fri Mar 22, 2024 11:31 am
Joe73 wrote:I just checked behind the dashpad itself.  Yes, there are two standoffs about 2" tall.  Something can easily be threaded into them.  I might give it a shot.  Thanks again for the idea.
You're welcome.
I'm glad you found them; helps convince me that I'm not going senile… yet.  1973 Chevelle SS, 350, 4spd. build - Page 17 1f609
zucchi
zucchi
Street Cred : 4
Joe73 likes this post
Post by 73ss Fri Mar 22, 2024 3:58 pm
Thanks for the pics guys. That will give me a general idea of what it looks like as far as the numbers and color, I think GM used green lettering on some models.
Joe in all your years of working on these cars you've never seen that heat sink? Also, I really like how your inner fender wells turned out.
Post by Joe73 Fri Mar 22, 2024 4:21 pm
Thanks. Im happy with the inner fenders as well. I actually dont remember any of my other 9 73 chevelles having anything other than an aftermarket or am radio.
Street Cred : 83
Post by 73 ss wgn Tue Apr 30, 2024 8:07 am
These are some pictures from the original salesman's optional equipment catalog and the sales brochure for 1973. My '73 was missing the original radio but did still have the amp behind the dash installed. I ended up installing a refurbished '76 model that allowed for four speaker outputs and you'd need to be real A-body obsessive to know it wasn't the one that came with the car, if you even could. The last picture is how to decode the label on the side of the radio if it is still there.
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_1413
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_1414
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_1415
73 ss wgn
Post by 73 ss wgn Tue Apr 30, 2024 8:12 am
Those pictures keep coming up upside down for some reason.
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_1416
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_1417
1973 Chevelle SS, 350, 4spd. build - Page 17 Gm_rad10
73 ss wgn
Limey SE likes this post
Post by mikidymac Wed May 01, 2024 2:34 pm
I can check my radio this weekend. I never removed it during the CD craze and made an aluminum mount inside the glovebox or a DIN CD player. My OEM radio has been in the dash since 73'.
mikidymac
mikidymac
Post by Joe73 Wed May 01, 2024 7:44 pm
mikidymac wrote:I can check my radio this weekend. I never removed it during the CD craze and made an aluminum mount inside the glovebox or a DIN CD player. My OEM radio has been in the dash since 73'.
Id like to know if the radio had any support brackets or is it just held to the dash by the knob stud nuts.
Street Cred : 83
Post by bracketchev1221 Thu May 02, 2024 7:57 am
I thought they had the stud on the back to hang on a little bracket in the rear. Even sometimes a piece of band steel with all the holes drilled in it.
Post by Joe73 Thu May 02, 2024 10:16 am
bracketchev1221 wrote:I thought they had the stud on the back to hang on a little bracket in the rear.   Even sometimes a piece of band steel with all the holes drilled in it.
Thats exactly how Ive always installed aftermarket radios. I have my original AM radio that came with the car but there arent any support brackets and I dont know if there supposed to be any.
Street Cred : 83
Post by zucchi Thu May 02, 2024 10:24 am
I recall there's one bolt (or bolt hole) on the side of the factory radio that attaches to the steel dash support. I could take a look at the service manual and illustrated parts manual when I get home from work this evening.
zucchi
zucchi
Street Cred : 4
Post by 73 ss wgn Fri May 03, 2024 5:49 am
On the driver's side of the radio there is a hole that a bolt slides into. That bolt fits into a slot on a metal plate mounted on the driver's side of the radio opening.
73 ss wgn
Post by jpowen49 Fri May 03, 2024 8:23 am
A picture of the bracket, hope this helps.1973 Chevelle SS, 350, 4spd. build - Page 17 Thumb106
jpowen49
jpowen49
Limey SE and zucchi like this post
Post by 77camino Fri May 03, 2024 8:27 am
73 ss wgn wrote:On the driver's side of the radio there is a hole that a bolt slides into. That bolt fits into a slot on a metal plate mounted on the driver's side of the radio opening.
I know these are not for a 73 but I have the stock am radios from my 77 El Camino and 74 Malibu and I have an am/fm from either a 76 or 77 Malibu that I found in a box in the back seat of a junkyard Malibu. The am/fm still had the side bracket attached to it and the am’s have the slot to attach to the same bracket.1973 Chevelle SS, 350, 4spd. build - Page 17 Img_3711
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_3710
1973 Chevelle SS, 350, 4spd. build - Page 17 Img_3712
Code:
[url=https://servimg.com/view/19285669/267][img]https://i.servimg.com/u/f91/19/28/56/69/img_3713.jpg[/img][/url]
zucchi likes this post
Post by zucchi Fri May 03, 2024 9:29 am
77camino wrote:1973 Chevelle SS, 350, 4spd. build - Page 17 Img_3713
It got lost somewhere in translation.
By the way, that along with jpowen49 image should answer your question.
zucchi
zucchi
Street Cred : 4
Post by Joe73 Fri May 03, 2024 8:13 pm
Thats exactly what I was looking for. Thanks guys for posting those pics. Answered my question.
Street Cred : 83
Post by Limey SE Sat May 04, 2024 2:27 pm
jpowen49 wrote:A picture of the bracket, hope this helps.1973 Chevelle SS, 350, 4spd. build - Page 17 Thumb106
Ok Who has that Mounting bracket for a single Speaker I have an Adapter plate for a dual Speakers already but seen to be missing them bolts to put on dash so Can and should be the single Speaker Option bracket for dash Speaker Need asap So I can put dash in
Post by Mitchell Murphy Wed May 08, 2024 8:09 am
To The Owner of the 1973 Chevelle SS 350 4 speed car, if you would like a copy of the Chevelle Report 1973 Silver anniversary Issue, let me know, the entire issue is devoted to the 1973 Chevelles. I will include the receipt for you . All are done on gloss paper. The last one i had done was about 16.00. My car is on the cover, 454 4 speed.. Take your time and do the car right, all the details add up and be worth it in the end. Thanks, Mitch
Mitchell Murphy
